A/D, Pot, Input, A,B So lost now....
Results 1 to 8 of 8
    Mar 2008
    wow, thanks for the reply.
    But damn now Im lost.
    Can I just read the AD converter value to a byte? Then use that as my pulse out. I think thats what that code above is doing, but also applying some limits and boot up procedures.
    I guess where Im getting most lost is how do I define what I am using on that pin? Or Will it just read what ever it wants to? Do I have to write it to a data spot or can I just use it as a variable?
    Servo VAR Portc.5
    Potin VAR AD.4 ' Can I do that? Or Do I call it something else to call the AD converter inside the pin.
    PULSE VAR BYTE
    Loop:
    READ AD.4, Pulse
    PULSOUT Servo, Pulse
    Pause 18
    Goto Loop
    Thanks again, Sorry I am new at this. Im trying.
    EDIT: Ok so super noob question, Is there a difference between calling a PIN by GPIO.? versus Porta.? or Pin 5. I get the port/pin references but I can seem to figure out where the GPIO comes from.
    Quote Originally Posted by Helmutt View Post
    Hello Helmutt,
    Yes, GPIO is for the PICs that have GPIO like the 12fseries as they only have 1 port. PortA, B, C are assigned to the ports you actually have. I E. a 16F628a has 2 ports, A & B, whereas another PIC might have several more A B C D . . .
    Mar 2008
    Ah cool, Finally stopped skipping over the 12 pin section and found that out. Thank you.
    Easy way...if you left justify the results, you can use the high byte of the result and use the upper 8 bits (low 2 bits ignored), if you right justify, you read both high and low byte of ADRES into a word
    As far as how to use the A/D converter, read the manual. There's an example in there, and while it doesn't fit all scenarios, it fits many of them.
  1. floating A/D input
    By muddy0409 in forum mel PIC BASIC Pro
    Last Post: - 28th April 2009, 13:21
  2. 12F675 A/D and GPIO sleep interrupt
    By macinug in forum mel PIC BASIC Pro
    Last Post: - 8th September 2008, 14:39
  3. Advice on Input circuitry for 0-10v or Pot
    By bcd in forum Schematics
    Last Post: - 12th April 2008, 10:47
  4. Question from New member A/D input 16f876
    By mbruno in forum General
    Last Post: - 26th January 2008, 14:52
  5. Replies: 4
    Last Post: - 24th January 2007, 22:20
