What you've done is a classic Tekkie line of thinking "Let's replace what's gone brown and crispy and it should all work fine thereafter".
You probably have a simple component failure, but what's smoked isn't the CAUSE - just the end result.
Before doing anything, check the Zener across the motor. It's there to stop any back-emf and over-voltage spikes going back and upsetting the drivers. We don't want to put fresh parts in to have them die immediately.
The Brake Q23 should never be on at the same time as the Driver Q22 - that much you know. Their respective circuits (Q16/17 for Q23 and Q13/14 for Q22) ensure this never happens because the Drive enable and the Brake are both driven from a common source. Obviously this isn't happening. Ignore the centre bit of the circuit Q1/Q4 and everything to the right… that 'convoluted logic' is absolutely NOTHING to do with motor control and brakes – believe it or not, that's all just pretty lights.
Remove Q23 that will stop any brake/short. Put in a fresh good Q22. Run the Motor and check you have speed control. If it's running full speed with no control, check Q13/14. When I say check Q13/14, it doesn't mean it's those parts and they have to be immediately replaced. I expect you to look at their respective voltages and determine if what you're looking at is sensible or not. You could have a dry joint, or a defective piece of track, or a Resistor that's died.
If you CAN vary the speed (remember you have no brake so it'll be relatively unresponsive), then your fault probably lies with either Q16/Q17 keeping the Brake on when it should't be. Remember, when finally returning the removed Q23, that you put back a good one.
The fun part is following the clues and finding the cause. You've got a circuit diagram - it should be a relatively simple task.
