Multiple analog inputs ?
Results 1 to 6 of 6
    you can also see http://www.picbasic.co.uk/forum/showthread.php?t=1659 or search the forums, there's lots of good info here.
    Feb 2008
    Go here for example code and it may also answer your question.
    http://www.rentron.com/PicBasic1.htm
    Then scroll to:
    Never had any problems with more than one myself.
    Do you have any examples which use ADCIN and put the input directly into the variable (see below) ? T
    Quote Originally Posted by nomad View Post
    Thanks ! Just to clarify, so my code below can work without problems ?
    define adc_bits 10 'define number of bits in result
    define adc_clock 3 'clock source3=RC
    define adc_sampleus 50 'set sampling time in microsec
    adcvar1 var word
    adcvar2 var word
    diff var byte
    start:
    adcin 0, adcvar1 'read channel 0 to adcvar1
    adcin 1, adcvar2 'read channel 1 to adcvar2
    diff = adcvar1-adcvar2
    select case diff
    Thanks guys. Any other links will be very helpful.
    Cool
    IF you want "real same time" measurements ... simply use :
    1) slow variatons : RC Low pass on ADC inputs to filter and "damp" a bit
    2) quick variations : External LF398 ( i.e.) Sample and Hold circuits ...
    3) Use two external ADCs
    4) Use a differential OPA ...
    And then use the ADC ... or read the ext ADCs.
    remember The Pic can do ONE THING ONLY at a time .... but can drive many peripherals at the same time ....
    Feb 2008
    Thanks Alain, but I dont think I need 'same time' measurements.
    OK, so I have read the links. If my code is like this
    pair1:
    adcin 0, adc1 'read channel 0 to adc1
    adcin 1, adc2 'read channel 1 to adc2
    diff = abs(adc1-adc2)
    if diff>tolerance then
    ' run servo1 for x seconds
    goto pair1 'recheck values
    meaning I repeatedly check the analog input until 'diff' is less than 'tolerance', there will be no problems as I have
    DEFINE ADC_SAMPLEUS 50
    at the top, and this will add the delay between each ADCIN automatically. Am I correct ? Just want to confirm.
    ps. I also read that sampling at 8 bits instead of 10 will improve the speed and stability when using multiple analog inputs. Will reducing to 8 bits help a lot, or can it work just fine with 10 bits ?
  1. Erratic analog inputs .
    By timseven in forum mel PIC BASIC Pro
    Last Post: - 10th October 2009, 23:34
  2. pic18f analog comparator problem
    By david.silaghi in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 10:38
  3. Many Analog Inputs
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 10th July 2006, 09:15
  4. multiple serial inputs
    By Richardco in forum mel PIC BASIC
    Last Post: - 25th November 2005, 22:26
  5. analog inputs on 16F716
    By schwinn_rider in forum mel PIC BASIC Pro
    Last Post: - 6th October 2005, 05:07
