LCD; silly n00b problem...
Results 1 to 10 of 10
    Feb 2008
    Default LCD; silly n00b problem...
    Hi guys, long term lurker first time poster!
    I have a silly problem...
    I have salvaged an old 1x16 lcd from a phone, I am sure it is HD44780 compatible.
    I am using a pic16f628, but when I try the program all I get is this;
    Any ideas?
    TIA
    Hi TIA,
    Looks like it is working, you need to add a contrast control.
    http://www.picbasic.co.uk/forum/showthread.php?t=49
    JS
    Feb 2008
    I have a variable resistor for the contrast, all I get is those blocks though...
    This is the code I have;
    PAUSE 1000
    LCDOUT $FE,1
    LCDOUT "Hello World!"
    STOP
    Is that correct?
    TIA - Thanks In Advance.
    Show us the whole code. Might be something in the defines.
    I would add and the circuit also.
    Feb 2008
    Ah, I think that might be the problem, that is the whole code!
    OK. And the connections? Are on port a any?
    Feb 2008
    I found a major problem! Pin 5 of the PIC was going to +5v not ground! [/sheepish]
    Now the display works, ish, but I am only getting the first 8 chars displayed...?
    Oct 2003
    holland
    And don't forget this lcdisplay is a 2x8 and not a 1x16 line display.
    So tell this in the beginning of your program when defining everything.
    I hate to write this but Read The Fine Manual. Sorry but you really have to. This PIC has analog comparators that need to be set prior at the top of your program. Something like:
    cmcon = 7 ' to disable portA comparators
    vrcon = 0 'disable reference voltage output at porta.2
    Also don't forget to use some DEFINE's (in capital letters!) to tell PBP what LCD you have and where it is connected (see at LCDout on page 95 of 3.04 manual version).
  1. LCD problem with 16F628
    Last Post: - 19th September 2016, 08:28
  2. Newbie? Problem with LCD
    By lew247 in forum mel PIC BASIC Pro
    Last Post: - 7th December 2009, 19:48
  3. Play with LCD on PICDEM
  4. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 11:43
  5. Need help with LCD number display.
