Math operations & Syntax?
Results 1 to 8 of 8
    If I'm reading your question correctly...
    %00010001
    is the same as
    %10001
    %00000001
    is the same as
    %1
    is the same as
    1
    is the same as
    $1
    Is this what you're thinking?
    Aug 2007
    No, sorry. Not what I was asking. lol.
    I'm asking if I create a 16 bit variable, and populate it by saying "myVar = TRM1", will it automatically plug the TMR1H and TMR1L values together and stick them into myVar?
    And if I add 100 to that value, then populate the timer registers again by plugging this variable back in like this "TMR1 = myVar", will the binary values of the 2 8-bit registers get split correctly and put back into TMR1H and TMR1L as appropriate?
    Quote Originally Posted by kevj View Post
    Ok, I got you...
    It may depend on the PIC, not sure, the datasheets will tell.
    But...
    I'm looking at the 18F4620 datasheet, there's a section in there under Timer 1 that talks about 8 bit vs 16 bit Timer 1 writes.
    Basically, you can't go TMR1 = var, you do actually have to use 2 8bit writes. You can't directly access TMR1H, it gets buffered in the 16 bit R/W mode. (section 12.2 of the 18F4620 datasheet)
    Aug 2007
    Ok, I got you...
    But...
    Okay perfect - that is exactly what I'm asking, and now the follow up...
    What is the exact syntax to split off the high and low bits? That really is my confusion at this point. I want to do something like this, but I'm not sure the syntax...
    myHolder VAR WORD
    ''' stop timer, which is now holding the result I want to measure
    myHolder (the low byte) = TMR1L
    myHolder (the high byte) = TMR1H
    myHolder = myHolder - 200
    ''' now I'll goto another sub where I'm using the timeout as a trial
    TMR1L = (the low byte of myHolder)
    TMR1H = (the high byte of myHolder)
    So I guess I'm just asking for the syntax of how to reference a high bit or a low bit in or out of a 16-bit variable, and also to clairify that once I have the value in "myHolder", I can do all the simple add/subtract math I want to it just like any normal variable as long as the values remain between 0 and 64,000andwhatever.
    Right? :-)
    myHolder VAR WORD
    Right? :-)
    It's all in the manual under the "Variables" section, highbyte, lowbyte, bitxxx, aliasing, whatever...
    These two threads should answer your question & then some. The 2nd using the EXT
    modifier is really nifty.
    http://www.picbasic.co.uk/forum/showthread.php?t=544
    http://www.picbasic.co.uk/forum/showthread.php?t=3891
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Aug 2007
    Thanks guys! Much appreciated!
  1. Resolution integer math assistance?
    Last Post: - 14th January 2010, 04:01
  2. PBPL Math...new math takes more cycles...Always?
    Last Post: - 10th February 2008, 11:22
  3. instruction cycles for math operations
    By Michael Wakileh in forum mel PIC BASIC Pro
    Last Post: - 28th July 2007, 12:03
  4. Math Operations on pbp
    By Jannia04 in forum mel PIC BASIC Pro
    Last Post: - 24th May 2007, 16:33
  5. PIC18Fxx math 24 & 32 bit
    By ronsimpson in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2006, 13:52
