CMCON0 = 7 wouldn't hurt either..;o}
Edit: Note that PBP defaults to 4MHz. If you're using the internal 31kHz osc, expect pretty much all timing to be way off.
I tried both suggestions, and it doesn't help. I am aware of the severe timing differences, but that shouldn't have anything to do with this, should it?
Thanks for your help.
Here's another possibility.
By setting WDTCON = %0000000
If the config bit's say _WDT_ON then you can't turn off the Watch Dog Timer with the WDTCON.0
However, in the process, it's reduced the WDT prescaler to 1:32
Since the processor is running so slow. the WDT might not be getting cleared often enough.
So, either try turning off the WDT in the configs. Or set WDTCON = %00010110 (1:65536)
hth,
Nice catch Darrel.
I would just set WDT_OFF with PBP assuming 4MHz, and running at 31kHz. Just in case. PBP will insert a NOP where it normally had a CLRWDT for timing, but there may be a library routine that doesn't hit the dog in time with the timing being so far out of whack.
Weird problem - just a comment
OPTION_REG defaults to $FF on power up. It looks like when you define the OPTION_REG value you are setting bits 4 and 5 but you are actually clearing bits 0-3 and 6-7. Bits 0-3 are harmless since they relate to the prescale of TMRO. Bit 6 sets the method of interrupt for RA2 - but the Interrupts are not enabled. That leaves Bit 7, which turns on the weak pull-ups. How strong of signal are you using to drive pin 11?
EDIT: a bit late but not the problem - glad it works
Last edited by paul borgmeier; - 16th February 2008 at 05:03. Reason: solution reached before my post
Paul Borgmeier
Salt Lake City, UT
USA
__________________
