16F688 counter problem
Results 1 to 9 of 9
    Here's another possibility.
    By setting WDTCON = %0000000
    If the config bit's say _WDT_ON then you can't turn off the Watch Dog Timer with the WDTCON.0
    However, in the process, it's reduced the WDT prescaler to 1:32
    Since the processor is running so slow. the WDT might not be getting cleared often enough.
    So, either try turning off the WDT in the configs. Or set WDTCON = %00010110 (1:65536)
    hth,
    I changed it to WDTCON = %00010110, and it works! Thank you!
    Nice catch Darrel.
    I would just set WDT_OFF with PBP assuming 4MHz, and running at 31kHz. Just in case. PBP will insert a NOP where it normally had a CLRWDT for timing, but there may be a library routine that doesn't hit the dog in time with the timing being so far out of whack.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Weird problem - just a comment
    OPTION_REG defaults to $FF on power up. It looks like when you define the OPTION_REG value you are setting bits 4 and 5 but you are actually clearing bits 0-3 and 6-7. Bits 0-3 are harmless since they relate to the prescale of TMRO. Bit 6 sets the method of interrupt for RA2 - but the Interrupts are not enabled. That leaves Bit 7, which turns on the weak pull-ups. How strong of signal are you using to drive pin 11?
    EDIT: a bit late but not the problem - glad it works
    Last edited by paul borgmeier; - 16th February 2008 at 05:03. Reason: solution reached before my post
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
  1. 16F688 problem
    Last Post: - 10th May 2009, 00:09
  2. Replies: 14
    Last Post: - 26th September 2007, 06:41
  3. UP/down counter & shiftout interupt problem
    Last Post: - 2nd July 2007, 16:56
  5. Problem with 16F688 and Hserout
    By DWV in forum mel PIC BASIC Pro
    Last Post: - 19th March 2005, 06:37
