Hpwm On 16f873
Results 1 to 5 of 5
Thread: Hpwm On 16f873
    Quote Originally Posted by k-hirayama View Post
    DEFINE CCP1_REG PORTB
    DEFINE CCP1_BIT 0
    DEFINE CCP2_REG PORTB
    DEFINE CCP2_BIT 1
    DEFINE CCP3_REG PORTB
    DEFINE CCP3_BIT 2
    Look at the '873 datasheet.
    How many CCP modules does the '873 have?
    What pins are those modules assigned to?
    Feb 2008
    Smile
    Hi
    thank you always.
    Sorry that I do not understand about ccp.
    usealy I see only about pin diagram in datasheet, so not know deeply understand about a PIC.
    873 have no ccp3, isn't it.
    a thing that I want to do is dim controll of LED to port B0-B7.
    I can't understand defnition of ccp.
    so I need sample program.
    Do realize port B0-B7 pwm controll at the same timing ?
    I know multiple pwm controll by ASM even low-end pic, but I can not do this.
    I dislike a C language like CCSC.
    pbp with MCS evironment is ideal for me. especialy the variable is seen. it's so good.
    regard.
    give this a shot . . .
    http://www.microchip.com/stellent/id...cName=en010235
    My bad. it seems the links do not go anywhere . . .
    Yes, you are correct, the '873 does not have a CCP3.
    Also, the datasheet's pin diagram's in the CCP module chapter also show which pins are connected to each of the remaining 2 CCP modules.
    There are more than a few examples (some very recent) of both software and hardware PWM control of pins on this site. All it takes is a bit of searching.
  1. need help on hpwm
    By helmut in forum mel PIC BASIC Pro
    Last Post: - 28th August 2007, 16:49
  2. HPWM of the port of two HPWM
    By ja2rqk in forum mel PIC BASIC Pro
    Last Post: - 25th April 2007, 16:05
  3. HPWM down
    Last Post: - 10th January 2007, 01:06
  4. sound command & music
    By trying in forum mel PIC BASIC Pro
    Last Post: - 26th May 2006, 15:14
  5. 3 HPWM channels
    Last Post: - 4th April 2006, 03:43
