Need to count higher than 255
Results 1 to 4 of 4
    May 2007
    Question Need to count higher than 255
    I am in a situation where I am controlling a stepper motor with a Pic and I need to count off up to 1900 stepps. Also I need to take the counted number of stepps and compare to another number to see which is higher or lower and subtract the difference. I guess I need to learn how to do natural math with Pics. For example: 1373 - 812 or whatever. I heard there are 'co-processors' but I dont know much about them. Does anybody have any ideas.
    Thanks in advance,
    Steve Matson
    Quote Originally Posted by Steve Matson View Post
    Thanks in advance,
    Steve Matson
    Get more fingers and toes....Or....
    Read in the PBP manual about Bits, Bytes, Words, and the variables that can be used with them...
    Next on Jerry Springer...
    Thanks in advance,
    Steve Matson
    Hi Steve,
    8 bits to a byte, 16 bits or 2 bytes to a word. Byte holds 0 - 255, word holds 0 - 65535
    Count binary, each time you add a bit to the left the value doubles which is to say 010 is twice the value of 001, so if 11111111 = 255 then 1 00000000 is 256 and 1 00000001 is 257 etc, if you are using windows, fire up the calculator, switch it to scientific mode and enter any number smaller than 65535 and then click the button marked " BIN " and you will see the binary representation which is how the number is positioned in the WORD.
    JS
    May 2007
    Default Thanks
    Thanks, That makes sense. I suppose there is some kind of way to add and subtract those hex numbers and count down as well as up. Is this 16 bit math the same as you would find in an 8085up ?
    Steve Matson
  1. Doubling the pusle count
    Last Post: - 17th May 2012, 14:17
  2. COUNT is not counting again
    Last Post: - 19th June 2009, 05:52
  3. Can't get COUNT to count
    Last Post: - 24th March 2009, 00:14
  4. Count pulses between VARIABLE TIME
    By RodSTAR in forum mel PIC BASIC Pro
    Last Post: - 15th October 2007, 13:44
  5. Count command
    By hawk72501 in forum mel PIC BASIC Pro
    Last Post: - 6th September 2005, 20:04
