Question for the PC guru's
Results 1 to 25 of 25
    Ok here's what I've found. On a system that doesn't have sufficient hard drive space to stash the hibernate file, you're essentially screwed.
    It will "appear" to enter hibernate mode, and auto-restart once it figures out there's not enough room to stash everything on your hard drive in this nifty hibernate file. Trial & error here.
    I was moving the mouse or pressing a key on the keyboard long before it figured this out, so it "appeared" the system was re-starting due to my moving the mouse or pressing a key.
    It just took a very long time for Windows to figure out there wasn't enough hard drive space to store this huge hibernate file.
    Switched to an XP system, with a boat-load of hard drive space available, and bingo. It does indeed give me the progress bar thing when entering hibernate, and it won't resume without a press on the power button.
    With stand by selected, it resumes as advertised with a mouse or key-press, but only if these are enabled in device manager.
    This is great BUT, it's totally worthless if there's not enough space on a hard drive to store the silly (and incredibly HUGE) hibernate file before hibernate shutdown, so this option is essentially worthless for the application. We really have no idea if a PC this will be installed on has the resources for hibernate to work. It would be awesome if it wasn't limited to hard drive space available.
    Huge bummer. It looked so easy.
    Edit: Yes. It does go through the bios screen when restarting from hibernate. Then it resumes with everything on-screen just like it was before entering hibernate.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    hibernat.sys should only be just a tad bigger than total memory installed (1GB mem = about 1.1GB hard drive space used).
    Yes, it's huge, but it's also generally placed at the 'front' of the drive, behind the paging file, for quick access.
    So, yes, if you're short on drive space, and don't have a lot of memory (and/or slow drives, etc), it'll begin to look pretty ugly pretty quick.
  1. LCD / PC question
    By luminas in forum mel PIC BASIC Pro
    Last Post: - 25th August 2008, 10:53
  2. Sending menu to PC from PIC16F876A
    By joseph Degorio in forum Serial
    Last Post: - 12th November 2007, 08:03
  3. PC Keyboard question
    By HatchetHand in forum mel PIC BASIC Pro
    Last Post: - 18th September 2007, 07:03
  4. 18F458 to PC communication Help
    By shawn in forum Serial
    Last Post: - 11th February 2007, 20:24
  5. Interrupt and Serial communication to PC.
    By obaskirt in forum mel PIC BASIC
    Last Post: - 17th June 2005, 21:01
