Question for the PC guru's
Results 1 to 25 of 25
    You've got IR badges?
    Yes.
    I take it that they shoot out an IR signal at regular intervals?
    Yes. The IR badge system works perfectly already. What I'm looking for is some way to
    eliminate several mechanical relays. If we can interface to the PC bus via a PCI or ISA
    card slot, and disconnect/disable input hardware, we can drop most of the relays.
    Physically switching input devices & video works fine, but if there's an easier way, which
    requires < hardware, I'm all ears...;o}
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Yes. The IR badge system works perfectly already. What I'm looking for is some way to eliminate several mechanical relays. If we can interface to the PC bus via a PCI or ISA card slot, and disconnect/disable input hardware, we can drop most of the relays.
    There has to be a way to send the 'Sleep' and 'Wakeup' keyboard commands over the USB port, if in fact the keyboards are USB. Heck, even PS/2 should work.
    This device is invisible to the operating system. There is no communications between it and the PC.
    -Bruce
    tech at rentron.com
    Jan 2006
    Istanbul
    And I guess no software intervention is desired nor is planned then.
    I was thinking; a small program works in background listening to an interrupt on PCI bus; and when it happens, the software disables the selected peripherals. As far as I know, there are 256 interrupt options. I might be wrong.
    Wouldn't this be an easier way?
    I am no PC guru BTW.
    Italy
    Resume from hibernate will always require the use of the power button.
    (The mouse or the keyboard will not wake the PC from hibernation).
    There are no communications pipes or connections between this hardware device & the PC, so there is no way for any software running on the PC to interact with it
    -Bruce
    tech at rentron.com
    I wish that were true. I setup my Windows ME machine to enter hibernate on a quick press of the power button.
    It works perfectly, but it will wake from hibernate on mouse movement or a key-press...;o}
    ME does not provide options to disable wakeup via mouse or keyboard.
    -Bruce
    tech at rentron.com
    Italy
    The PC is probably not going to hibernation. The PC is powerd off when it goes to hibernation.
    The hibernate feature saves everything in memory on disk, turns off your monitor and hard disk,
    and then turns off the computer.
    When you resume from hibernation the BIOS performs the typical Power On Self Test (POST),
    and then reads the hibernation file, Hiberfil.sys, to restore the state of the computer.
    Everything that was running when you put the computer in hibernation is restored.
  1. LCD / PC question
    By luminas in forum mel PIC BASIC Pro
    Last Post: - 25th August 2008, 10:53
  2. Sending menu to PC from PIC16F876A
    By joseph Degorio in forum Serial
    Last Post: - 12th November 2007, 08:03
  3. PC Keyboard question
    By HatchetHand in forum mel PIC BASIC Pro
    Last Post: - 18th September 2007, 07:03
  4. 18F458 to PC communication Help
    By shawn in forum Serial
    Last Post: - 11th February 2007, 20:24
  5. Interrupt and Serial communication to PC.
    By obaskirt in forum mel PIC BASIC
    Last Post: - 17th June 2005, 21:01
