Numeric value for Photoresistor/LDR value
Results 1 to 12 of 12
    Apr 2007
    I find the question a bit cryptic...
    "Reading of 50kohms on the multimeter - what will the numeric value then..?
    50,000 if I read the question right.
    Are you trying to determine the resistance of the LDR? The relative amount of light falling on the LDR? The price of a good pizza in Sau Paulo? And display those results on an LCD?
    Maybe something is getting lost in translation.
    Hook us up with a bit more info.
    Actually i want to know the reading of resistance of the LDR...
    I came across an experimental board with an LCD onboard.
    so here it stated with the programm..
    pot portb.1,255,v1 'read resistance of cds photocell.
    "along the programm it writen display information to the lcd."
    so the lcd will give a value example 37 under certain light condition from the LDR.
    Hence it can be compared by a value..
    example:
    the ldr is set to variable V1.
    If v1 <= 100 then skp 'compared the value from the LDR with 100.
    My question here..if i do not have this experimental board, is there a way to know the actuall reading of the LDR?
    pot portb.1,255,v1 -------- does the value 255 will be the maximum. and comparison will be from 0 - 255.?
    thanks alot..
    The ADC example will do it.
    If you use 10 bit resolution for the ADCthe value can be 0 to 1024.
    Quote Originally Posted by tech View Post
    thanks alot..
    You do realize that this number that you read from the ADC will be a 'relative' number, not an actual resistance value from the LDR, i.e. 10 doesn't mean 10K or 10M or 10 ohms, it just means that 10 is less than 11 and more than 9.
    You'll have to do your own math, scaling, etc. and probably end up using a lookup table of some sort to get actual resistance values. (unless you use trial and error, read a load of numbers, plug them all into a spreadsheet and find a non-linear equation that just happens to fit the curve)
    Apr 2007
    actually im trying to used pic to switch led at a different light falling to the ldr.
    now im connecting portb1 with an ldr(other end of the ldr leg to the portb1 and the other to the ground), portb6 and 7 will be the output led.
    v1 var byte
    pot portb.1,255,v1
    if v1 < 100 then lmp1
    if v1 > 100 then lmp2
    lmp1:
    high 6
    low 6
    lmp2:
    high 7
    low 7
    is this the way to programm? or i got a wrong connection on the circuit..
    need help..thanks..
    Do not use high ?. Use PORT?.? instead, works much better.
    Here is some code to look at. My LCD is on PORT B so the pins are different than yours but you can get the idea.
    '16F877A
    DEFINE OSC 20
    'LCD SET UP
    DEFINE LCD_DREG     PORTB
    define LCD_DBIT     4
    DEFINE LCD_RSREG    PORTB
    DEFINE LCD_RSBIT    1
    DEFINE LCD_EREG     PORTB
    DEFINE LCD_EBIT     0
    DEFINE LCD_BITS     4
    DEFINE LCD_LINES    2
    DEFINE LCD_COMMANDUS    2000
    DEFINE LCD_DATAUS   50
    V1		VAR	BYTE
    LED	VAR	PORTD.2
    PAUSE 1000
    RUN:
    LCDOUT $FE,1,"POT"
    LCDOUT $FE,$C0,DEC V1
    PAUSE 100
    POT PORTC.7,127,V1
    IF V1 < 100 THEN
    GOTO LMP1
    GOTO LMP2
    GOTO RUN
    LMP1:
    HIGH LED
    GOTO RUN
    LMP2:
    LOW LED
    GOTO RUN
    Hi Tech. I've used the LDR's in the past but read them with the ADCIN command. I've found ADCIN is easier & more accurate to work with. Also, your "if V1" statements have a slight glitch. If the value is exactly 100, the PIC will do nothing.
    v1 var byte
    portb = 0 'all off
    adcin 0,v1
    if v1 >= 100 then lmp2 'added if equal to
    lmp1:
    high portb.6
    low portb.6
    goto main 'return is for GOSUB's
    lmp2:
    high portb.7
    low portb.7
    Apr 2007
    Quote Originally Posted by peterdeco1 View Post
    v1 var byte
    portb = 0 'all off
    adcin 0,v1
    lmp1:
    high portb.6
    low portb.6
    lmp2:
    high portb.7
    low portb.7
    im using picf16f84a..
    Found out ADCIN did not work for pic16f84..
  1. DT's instant interupts compile problem
    By comwarrior in forum General
    Last Post: - 18th October 2009, 20:30
  2. Formating numeric values to text
    By Andre_Pretorius in forum General
    Last Post: - 1st August 2009, 09:39
  3. EDTP Ethernet MINI PICBASIC PRO DRIVER
    By edtp in forum mel PIC BASIC Pro
    Last Post: - 1st May 2008, 23:00
  4. Saving numeric data to eeprom from array
    By joseph Degorio in forum Serial
    Last Post: - 14th December 2007, 06:18
  5. Numeric Values
    By Armando Herjim in forum General
    Last Post: - 28th June 2006, 02:54
