Numeric value for Photoresistor/LDR value
Results 1 to 12 of 12
    Hi Tech. I've used the LDR's in the past but read them with the ADCIN command. I've found ADCIN is easier & more accurate to work with. Also, your "if V1" statements have a slight glitch. If the value is exactly 100, the PIC will do nothing.
    v1 var byte
    portb = 0 'all off
    adcin 0,v1
    if v1 < 100 then lmp1
    if v1 >= 100 then lmp2 'added if equal to
    lmp1:
    high portb.6
    low portb.6
    goto main 'return is for GOSUB's
    lmp2:
    high portb.7
    low portb.7
    Apr 2007
    Quote Originally Posted by peterdeco1 View Post
    v1 var byte
    portb = 0 'all off
    adcin 0,v1
    lmp1:
    high portb.6
    low portb.6
    lmp2:
    high portb.7
    low portb.7
    im using picf16f84a..
    Found out ADCIN did not work for pic16f84..
  1. DT's instant interupts compile problem
    By comwarrior in forum General
    Last Post: - 18th October 2009, 20:30
  2. Formating numeric values to text
    By Andre_Pretorius in forum General
    Last Post: - 1st August 2009, 09:39
  3. EDTP Ethernet MINI PICBASIC PRO DRIVER
    By edtp in forum mel PIC BASIC Pro
    Last Post: - 1st May 2008, 23:00
  4. Saving numeric data to eeprom from array
    By joseph Degorio in forum Serial
    Last Post: - 14th December 2007, 06:18
  5. Numeric Values
    By Armando Herjim in forum General
    Last Post: - 28th June 2006, 02:54
