wildbilly,
Great, glad that's working for you.
I can't answer the main question, as I've never tried to go more than a couple inches to an LCD.
But, I'll agree that serial might be a better way.
However, I think there's two possible sources for the garbled text. And I might be able to do something about one of them if you still want the parallel interface.
- PBP sends everything out to the LCD at the MINIMUM pulse widths defined in the HD44780 datasheet. Which means approximately 1 Mhz squarewave signals since the enable pulse only lasts 1 uS. That's going to be tuff to get through 20 feet of ribbon cable.
<br>- The other source could be inductive pick-up, like an antenna.
Can't help much if that's the case.
If the problem is #1? It may be possible to slow down the LCD data to a point that will propagate thru the long ribbon.
Using the technique described in the LCD_Anypin thread, we could create whatever timing is required to slow it down to a reasonable speed.
If you want to try, let me know.
You'll have to do the testing though.
