Maximun Cable Length for PIC to LCD
Results 1 to 40 of 53
    Sep 2005
    Campbell, CA
    I think the problem is that it is just plain too cold where you live!
    Charles Linquist
    Ontario Canada
    That's a good laugh. I thought someone would have that reply.
    Quote Originally Posted by wildbilly
    Darrel I have installed the Highjack routines and also included the LCD_Anypin.pbp and VirtualPort.bas in the PBP folder. I then added the Include file in my main program just below the define Parameters.
    Excellent!
    Does your main program have this section (modified for your hardware of course).
    The old lcd DEFINES can be commented out.
    ;----[ Change these to match your LCD ]---------------------------------------
    </i></b></font><b>LCD_DB4   </b><font color="#008000"><b>VAR </b></font><b>PORTA</b>.<font color="#800000"><b>0
    </b></font><b>LCD_DB5   </b><font color="#008000"><b>VAR </b></font><b>PORTB</b>.<font color="#800000"><b>3
    </b></font><b>LCD_DB6   </b><font color="#008000"><b>VAR </b></font><b>PORTB</b>.<font color="#800000"><b>7
    </b></font><b>LCD_DB7   </b><font color="#008000"><b>VAR </b></font><b>PORTC</b>.<font color="#800000"><b>1
    </b></font><b>LCD_RS    </b><font color="#008000"><b>VAR </b></font><b>PORTD</b>.<font color="#800000"><b>4
    </b></font><b>LCD_E     </b><font color="#008000"><b>VAR </b></font><b>PORTA</b>.<font color="#800000"><b>1
    </b></font><b>LCD_Lines     </b><font color="#008000"><b>CON </b></font><font color="#800000"><b>2    </b></font><font color="#0000FF"><b><i>' # of Lines on LCD,  1 or 2 (Note: use 2 for 4 lines)
    </i></b></font><b>LCD_DATAUS    </b><font color="#008000"><b>CON </b></font><font color="#800000"><b>50   </b></font><font color="#0000FF"><b><i>' Data delay time in us
    </i></b></font><b>LCD_COMMANDUS </b><font color="#008000"><b>CON </b></font><font color="#800000"><b>2000 </b></font><font color="#0000FF"><b><i>' Command delay time in us
    </i></b></font><font color="#008000"><b>INCLUDE </b></font><font color="#FF0000">&quot;LCD_AnyPin.pbp&quot;  </font><font color="#0000FF"><b><i>; *** Include MUST be AFTER LCD Pin assignments ****</i></b></font>
    Ontario Canada
    Hi Darrel. I added the list below and no longer have the error but no longer have a display on
    the LCD. I only have two black bars.
    'LCD_DB4 VAR PORTB.0
    'LCD_DB5 VAR PORTB.1
    'LCD_DB6 VAR PORTB.2
    'LCD_DB7 VAR PORTB.3
    'LCD_RS VAR PORTB.4
    'LCD_E VAR PORTB.7
    The list below works fine.
    'LCD Parameters
    DEFINE LCD_DREG PORTB ' LCD Data port
    DEFINE LCD_DBIT 0 ' starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_RSREG PORTB ' LCD Register Select port
    DEFINE LCD_RSBIT 4 ' LCD Register Select bit
    DEFINE LCD_EREG PORTB ' LCD Enable port
    DEFINE LCD_EBIT 7 ' LCD Enable bit
    DEFINE LCD_BITS 4 ' LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 4 ' Number of lines on LCD
    DEFINE LCD_COMMANDUS 2000 'Command delay time in us
    DEFINE LCD_DATAUS 50 'Data delay time in us
    My LCD is connected just like your example " http://www.pbpgroup.com/files/2_LCDs.gif
    Bummer,
    OK, let me re-create it here.
    Back at ya soon.
    OK,
    Just to make sure, I went thru the steps again myself.
    Have it working here on a 16F88. One thing I had to add that wasn't mentioned here, although it was in the other thread ...
    PAUSE 500 : LCDOUT $FE,1 : PAUSE 250 ; Initialize LCD (You may not need this,
                                         ;  but some displays are picky)
    But so that I can compare Apples to Apples, What PIC are you using?
    I bought 25ft of ribbon today, just to make sure. But haven't hooked it up yet.
    Ontario Canada
    I added the code
    with the same result. I am using the 16F877a
  1. 16f688 LCD what have I done wrong
  2. Play with LCD on PICDEM
  3. DS1820 Max Cable length ?
    By dccch in forum General
    Last Post: - 24th January 2008, 07:44
  4. Measure cable length with a PIC?
    Last Post: - 15th July 2007, 18:45
  5. Need help with LCD number display.
