rf problem
Results 1 to 10 of 10
Thread: rf problem
    out of curiosity, what happen if you use T2400 instead?
    which PIC?
    How far away your RF modules are ?
    Are they sharing the same psu?
    Jul 2007
    which PIC?
    its a good old 16f84
    i shall try t2400 now
    i have my transmit setup - pic on one breadboard/ transmitter module on another connected up to each other
    same with receive, the transmit and receive part are not close to each other, tried them close and far still no result
    the transmit and receive side are individually powered with a 9v battery using a 5v voltage regulator
    You're using the wrong serial mode numbers for SERIN2/SEROUT2.
    Drop the include modedefs.bas and use something like N2400 CON 16780.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jul 2007
    bruce, i cannot thank you enough
    this has been annoying me for ages
    oops... missed that...
    STRONG AND BLACK COFFEE TIME!
    Jul 2007
    just looked up serin2 in the manual
    oops
    i thought modes were the same as serin when there ermm not..
    newbie mistakes..
    but at least i learnt from it
    another thing that it fixed..
    i was having strange timing issues to and that simple change fixed it
    Hey! I learn more from my mistakes than anything else. And those lessons are the easiest
    ones to remember.
    But, like mister-e has pointed out, I am getting old so I jot things down so I don't
    forget...;o}
    -Bruce
    tech at rentron.com
  1. problem with sending data using RF module
    By rano_zen06 in forum mel PIC BASIC Pro
    Last Post: - 10th April 2008, 18:08
  2. Problem with manchester code for RF
    By Dhanushka in forum mel PIC BASIC Pro
    Last Post: - 6th August 2007, 12:46
  3. RF range problem
    By George in forum Off Topic
    Last Post: - 19th March 2007, 05:11
  4. a problem RF Signal with PULSIN
    By muskut in forum mel PIC BASIC Pro
    Last Post: - 22nd July 2005, 17:42
  5. problem with RF receiver
    By nanami7702002 in forum mel PIC BASIC Pro
    Last Post: - 31st January 2005, 22:55
