rf problem
Results 1 to 10 of 10
Thread: rf problem
    If you're using 1 PIC, your example is not going to work as it can't receive at the same time he send. Using the PIC hardware Usart may work with some tricks such as USART interrupt.
    As always, your PIC # and schematic would be welcome
    Make sure your module are not to close from each other, your supply lines are clean/noise free, and the output signal of your receiver is also noise free in idle mode.
    Jul 2007
    sorry if i worded my post wrong, i am using 2 pic's one to transmit, and one to receive.
    it works with a direct link between the two mcu's
    and i'm using the good old 16f84a just wanted to start off simple
    transmitter code
    include "modedefs.bas"
    'transmitter on portb.1
    trisb.1=0
    transmit_data var byte
    restart_counter var byte
    restart_counter=0
    init:
    pause500
    lcdout "Serial"
    lcdout $fe,$c0, "Transmitter"
    for transmit_data=0 to 100
    serout2 portb.1,n2400,[$55,$55,$60,transmit_data]
    lcdout $fe,1
    lcdout "Transmitting"
    lcdout $fe,$c0,dec3 transmit_data, " "
    if transmit_data=100 then restart_timer
    next transmit_data
    restart_timer:
    lcdout $fe,1 ' clear lcd
    for restart_counter=0 to 10
    lcdout "Data sent"
    lcdout $fe,$c0, "restart in10:",dec2 restart_counter," "
    if restart_counter=10 then main
    next restart_counter
    goto restart_timer
    receiver code
    'receiver on portb.0
    trisb.0=1
    data_received var byte
    data_received=0
    init:
    pause500
    lcdout "Serial Data"
    lcdout $fe,$c0, "Receiver"
    lcdout $fe,1
    lcdout "Waiting For"
    lcdout $fe,$c0, "Data"
    serin2 portb.0,n2400,[wait($60),data_received]
    lcdout "Receiving Data"
    lcdout $fe,$c0,dec3 data_received," "
    out of curiosity, what happen if you use T2400 instead?
    which PIC?
    How far away your RF modules are ?
    Are they sharing the same psu?
    Jul 2007
    which PIC?
    its a good old 16f84
    i shall try t2400 now
    i have my transmit setup - pic on one breadboard/ transmitter module on another connected up to each other
    same with receive, the transmit and receive part are not close to each other, tried them close and far still no result
    the transmit and receive side are individually powered with a 9v battery using a 5v voltage regulator
    You're using the wrong serial mode numbers for SERIN2/SEROUT2.
    Drop the include modedefs.bas and use something like N2400 CON 16780.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jul 2007
    bruce, i cannot thank you enough
    this has been annoying me for ages
    oops... missed that...
    STRONG AND BLACK COFFEE TIME!
    Jul 2007
    just looked up serin2 in the manual
    oops
    i thought modes were the same as serin when there ermm not..
    newbie mistakes..
    but at least i learnt from it
    another thing that it fixed..
    i was having strange timing issues to and that simple change fixed it
  1. problem with sending data using RF module
    By rano_zen06 in forum mel PIC BASIC Pro
    Last Post: - 10th April 2008, 18:08
  2. Problem with manchester code for RF
    By Dhanushka in forum mel PIC BASIC Pro
    Last Post: - 6th August 2007, 12:46
  3. RF range problem
    By George in forum Off Topic
    Last Post: - 19th March 2007, 05:11
  4. a problem RF Signal with PULSIN
    By muskut in forum mel PIC BASIC Pro
    Last Post: - 22nd July 2005, 17:42
  5. problem with RF receiver
    By nanami7702002 in forum mel PIC BASIC Pro
    Last Post: - 31st January 2005, 22:55
