Controlling AC motors
Results 1 to 24 of 24
    Jun 2007
    Mansfield, UK
    They are Rotalink 5025-24050-30B. Google found nothing and i cant find that exact model on their site. shame they dont have a search box
    Wink
    Quote Originally Posted by The Master View Post
    Decoding their code ...
    shows 5024 is a 24 mm thick case and 5025 a 25 mm thick case ...
    You'd better send them a mail ... for your problem !
    Jun 2007
    Mansfield, UK
    This is a general question for any motors like that. There are some others that i would like to do the same thing with but i dont know the numbers of those.
    It seems like they were designed to move in a random direction. I just want to know what causes the randomness so maby i can make it predictable.
    Not sure about these motors but the other ones i have will change direction if you stop them with your hand.
    I think i might end up with a simple on/off circuit instead of directional control
    Italy
    What is the number of leads coming out of the motor?
    Best regards,
    Luciano
    Jun 2007
    Mansfield, UK
    Just 2. Its not a stepper motor (shame)
    Italy
    If your AC synchronous motor has only two leads (one winding), then
    you cannot control the initial direction unless the motor uses a
    mechanical device (anti-return) which is placed on the rotor.
    Reversible AC Synchronous Motors have 4 leads or more. (Two windings or more).
    Example of Reversible AC Synchronous Motor:
    Best regards,
    Luciano
    As you have probably figured out by now the "B" stands for Bidirectional.
    Motors like this are designed to change directions under a certain load or if stopped. (light bar in scanner?)
    Like Alain said, contact the manufacturer to find out how they did it in this motor but it is most likely like Luciano shows with the CW/CCW built in on an actuator. Now if you feel lucky take one apart and see if they can be bugged into.
  1. DC to AC convertor
    Last Post: - 6th February 2010, 17:44
  2. Controlling stepper motor with PIC
    Last Post: - 1st July 2008, 10:21
  3. Circuit Diagram for interfacing AC to PIC IC?
    By wellyboot in forum Schematics
    Last Post: - 8th March 2008, 19:40
  4. How to read AC mains with an inductance coil
    By KB3BYT in forum mel PIC BASIC Pro
    Last Post: - 20th February 2008, 12:02
  5. Special Offer AC -AC adapter
    By lester in forum Adverts
    Last Post: - 9th September 2005, 07:52
