Just 2. Its not a stepper motor (shame)
If your AC synchronous motor has only two leads (one winding), then
you cannot control the initial direction unless the motor uses a
mechanical device (anti-return) which is placed on the rotor.
Reversible AC Synchronous Motors have 4 leads or more. (Two windings or more).
Example of Reversible AC Synchronous Motor:
Best regards,
Luciano
As you have probably figured out by now the "B" stands for Bidirectional.
Motors like this are designed to change directions under a certain load or if stopped. (light bar in scanner?)
Like Alain said, contact the manufacturer to find out how they did it in this motor but it is most likely like Luciano shows with the CW/CCW built in on an actuator. Now if you feel lucky take one apart and see if they can be bugged into.
I see. I was hoping there would be a controllable reason why they go a random direction on startup. I will just make a simple on/off circuit for them then.
mackrackit, they are in abstract twister 3's
Thanx everyone for your help
You have lost me, but it has been a long day.mackrackit, they are in abstract twister 3's
Hi Dave,
I had to google in order to find out.
The new Twister 4:
http://www.abstractavr.com/products/twister4.php
Best regards,
Luciano
Yeah. I should upgrade to twister 4's. All my other FX lights are DMX. The new stuff is just too expensive though. I would like to Martin MX-4's. Im still using the MX-1's. lol.
