DTMF dial tone
Results 1 to 15 of 15
Thread: DTMF dial tone
    Sep 2006
    ok but what is off hook.
    I mean I have a dual splitter from the telephone line. One line goes to a telephone and the second line will go to the Pic chip. When I need to dial from the chip, how do I do an auto hook off on the telephone line so I can use the DMTFOUT command?
    k
    Mar 2006
    Hyderabad (India)
    Quote Originally Posted by lerameur View Post
    k
    As I already told in in the earlier reply, themoment you lift the hanset from the telephone , it is called OFFHOOK. Now in your contest- you may know that the exchange gives a voltage of 48V DC with a max current limit of 35mA. this current will flow thro the switch provided in the instrument. in your case you have to provise a trmnsformer primary loop thro' a relay contact controlled by you . then if the loop is extended , it is called OFFhook
    this can be checked by inserting a DMM in DC mA range in series to one of the limbs by breaking the connection and inserting the Meter for current measurement.
    Sarma
    Sep 2006
    anybody have a schematic of this?
    Mar 2006
    Hyderabad (India)
    Download the hardware datasheet UM91215 from www.alldatasheet.com
    you will find entire telephone circuit diagramover there.
    see how they implemented in hardware. you can convert it functionally to PIC
    Sarma
    Default YouŽll need a wet transformer
    Wet transformers with 600:600 impedance are built to match telephone line Z.
    This kind of transformer allows DC voltage levels to go through their nucleus without being saturated.
    Connect your line to one of this transformers to off-hook
    Mar 2006
    Pennsylvania, USA.
    You might take a look at Cermetek's website, as what you really need is known as a DAA. The phone company outputs 48 volts dc normally to your home phone, and when the phone rings there is a 20 Hertz ac superimposed onto the line that is usually between 90 and 120 volts. If you connect a PIC directly to the line you will likely fry the PIC, and you are also liable for any damage that you cause to the telephone company's equipment. Anything that you connect to a phone line is required by law to have agency approval, here in the United States that means the FCC. The Cermetek units will signal the PIC when the phone is ringing, and allow the PIC to go 'off-hook.' They also provide all neccessary isolation so that your PIC and the phone line are both safe, as well as the hybrid circuitry to get you from two wire to four. You will need to filter the DTMF out of the PIC using the circuit in the PICBASIC manual before you feed it into the DAA. Clare also has units that might fit your project, both of these companies are well known in telecommunications circles.
    You might find it easier, if all you need to do is ring a telephone, to find an old modem and connect it to the PIC using RS-232. Then you can just send AT commands to dial the telephone. The DTMF signals will be produced in your modem. Since you aren't concerned about speed, any old 2400 baud or whatever you can find will work fine. There are millions of old modems out collecting dust since now almost everyone is using ethernet to connect to the Internet. E-bay has a bunch of brand new external modems, you can buy one for ten bucks!
    Jerry.
    If your oscilloscope costs more than your car...
    Sep 2006
    using a modem is a good idea, plus I have a few of those 33.3 external modem laying around. just have to figure out how to hook it up to a pic but that should be too hard. thanks
    ken
  1. DTMF on a 12V car system
    By Jumper in forum Schematics
    Last Post: - 7th December 2008, 14:41
  2. Replies: 2
    Last Post: - 31st July 2006, 16:06
  3. Round Dial, Electronic Combination Lock
    By Pic_User in forum Off Topic
    Last Post: - 6th July 2006, 13:34
  4. Problems with DTMF Generatiom
    By Angus Anderson in forum mel PIC BASIC Pro
    Last Post: - 30th May 2006, 21:12
  5. A little DTMF help
    By Travin77 in forum mel PIC BASIC Pro
    Last Post: - 30th May 2006, 01:31
