PDFSUSB.exe source
Results 1 to 40 of 48
    Jun 2007
    Default too many
    hi, too many headers ,
    if you may send me a full copy , I will post an easy web link .
    VrBitmapDial.hpp
    VrControls.hpp
    VrAngularMeter.hpp
    VrLabel.hpp
    VrLeds.hpp
    VrSwitch.hpp
    VrCheckLed.hpp
    VrScope.hpp
    Aug 2007
    Sorry, I just checked the full ZIP and there are no .HPP files. I didn't delete anything in the smaller ZIP except:
    *.~* (e.g. file.~cpp, file.~h, etc... since these are temporary files)
    *.o (generated when you compile)
    *.tds (debugger symbols, generated when you compile)
    (possibly), *.obj (not sure - might be generated when you compile)
    *.exe (generated when you compile)
    PICBOOT.dll (available from binary distribution)
    Everything else is still there It looks like the source I have is incomplete.
    Jun 2007
    still , do u mind sending me the full copy , I will try to test it
    Thank you
    djohn's Avatar
    djohn Guest
    Default need a copy (for all)
    can someone share the source code thru a file hosting site like rapidshare, mihd etc. and post a link here. It will serve all.
    Thanks.
    Jun 2007
    its already attached above ,,
    sorry I was wrong , I source above is fine , it was my mistake
    I didn't installed borland C++ right ,
    everything now is ok , and again , the source code above is working
    Thank you all
    Aug 2007
    Quote Originally Posted by djohn View Post
    Thanks.
    You go ahead. The file is attached to a previous post for all to download, feel free to redistribute via rapidshare etc.
    Jan 2008
    Default who can send me one copy of it?
    I need the source code for PDFSUSB.exe .
    [email protected]
    I will try to attach a split file of PICDEMUSBFSDemoTool.
    This may take 5 posts.
    Norm
    Feb 2008
    Default I also can't compile
    Quote Originally Posted by viewgsm View Post
    VrBitmapDial.hpp
    VrControls.hpp
    VrAngularMeter.hpp
    VrLabel.hpp
    VrLeds.hpp
    VrSwitch.hpp
    VrCheckLed.hpp
    VrScope.hpp
    I also miss those header, I saw someone said it is because install the BCB wrongly, can anyone tell me how can i install the BCB correctly.
    Jan 2006
    Toronto
    No its part of a separate custom control suite and not part of Borland's suite at all.
    Jan 2008
    Arrow You can found those header files there.
  1. Filling pdu array with gps data!
    By camolas in forum mel PIC BASIC Pro
    Last Post: - 4th October 2008, 01:54
  2. Replies: 1
    Last Post: - 21st February 2008, 16:36
  3. Replies: 0
    Last Post: - 15th December 2006, 20:16
  4. Remote Control receiver - input source switching
    Last Post: - 16th October 2006, 22:20
  5. Source for PDFSUSB.exe
    By Braschi in forum USB
    Last Post: - 28th July 2006, 12:29
