PDFSUSB.exe source
Results 1 to 40 of 48
    3rd Post Split files.
    Norm
    4th and final post.
    Down load all files (1 through 18) to a folder.
    Remove the .TXT from each file name and click the .exe file to unzip.
    Norm
    File compare shows a valid file uploaded.
    Norm
    Jan 2008
    Thumbs up Thank you Norm
    I've got the source files you posted above.
    And compiled&rebuilt the project successfully.
    It runs ok.
    Thanks a lot.
    paketorro's Avatar
    paketorro Guest
    Default Linker Error
    I have downloaded the files and I have found that there is still some header files missing regarding with Controls of the DemoTool page. In my case these file are not so necessary, since I just want to build a simple application for downloading HEX files, so I have deleted them.
    Now I can successfully compile the project with Borland Builder 6.0 but there is still a linker error: [Fatal Linker Error] Fatal: Unable to open file 'VCWB6.LIB'
    Can anyone help me, since I am not used to Borland Builder. If anyone can post the source files for Visual Studio will be fine as well.
    Thanks.
    Jan 2008
    Lightbulb
    You need to install TMS Instrumentation Workshop in your bcb6.0.
    Feb 2008
    Default I ported the FSUSB App to VC++
    Thanks to Hunter2 for posting the ZIP of the PICDEMUSBFSDemoTool source.
    It's done in Borland C++ Builder, so I ported it to VC++.
    Details here: http://www.dlwrr.com/electronics/picdem/index.html
    Aug 2008
    Quote Originally Posted by paketorro View Post
    I'm currently working on recompiling and building the PICDEMUSBFSDemo software project with C++ Builder 2007. I've installed the TMS Software from the link above for Builder 2007 (although the installation locked at the very end). I'm also getting the error pertaining to VCWB6.lib. I've searched my hard drive for this library but cannot find it, I've also tried googling for it although end up unsuccessful. Is this library even required for what I'm doing, or should it have installed with the installation of the Instrumentation Workshop software? I'm really new to all this, I appreciate any help.
    Thank you
    Aug 2008
    Quote Originally Posted by sjpast View Post
    Thank you
    Ok, never mind. Thanks to dlchambers for his work with the visual studio route, I've been able to accomplish what I've needed using that rather than the original code with Borland.
  1. Filling pdu array with gps data!
    By camolas in forum mel PIC BASIC Pro
    Last Post: - 4th October 2008, 00:54
  2. Replies: 1
    Last Post: - 21st February 2008, 15:36
  3. Replies: 0
    Last Post: - 15th December 2006, 19:16
  4. Remote Control receiver - input source switching
    Last Post: - 16th October 2006, 21:20
  5. Source for PDFSUSB.exe
    By Braschi in forum USB
    Last Post: - 28th July 2006, 11:29
