Apparent code size problem
Results 1 to 11 of 11
Threaded View
  1. #3
    Jan 2006
    Istanbul
    Quote Originally Posted by eetech View Post
    IF (OhmCheck = FAILED) or _  	' resistor out of tolerance or
        (FlagResult <> 0) then                 ' hardware flag
        GOSUB Houston
    Try this for the one above:
    IF ErrCnt > 1 or FlagResult > 0 THEN GOSUB Houston
    Replace it with this one and it does not work:
    IF OhmCheck = FAILED THEN
       ErrCnt = ErrCnt + 1
       IF ErrCnt = 1 then	'first time gets a pass for a recheck
          Device = DISPLAY
          GOSUB SetCtrl
          LCDOUT $FE,1,"Chk Dckbill conn"
          LCDOUT $FE,$C0,"then retry test"
          PAUSE 1000
    IF (ErrCnt > 1) or (FlagResult <> 0) THEN
       GOSUB Houston
    And try this for the one above:
    IF OhmCheck = FAILED or FlagResult > 0 then GOSUB Houston
    And try this separately:
        ErrCnt = ErrCnt + 1
            Device = DISPLAY
            GOSUB SetCtrl
            PAUSE 1000
            gosub Houston
    IF FlagResult > 0 THEN GOSUB Houston
    Question: Do you set ErrCnt = 0 before the program starts running, or it gets some values from somewhere else?
    In your code, it seems that it must be set to zero at initial power up before coming to "IF OhmCheck = FAILED THEN" condition.
    Question: FlagResult is a hardware flag. So it can be 1 or 0 only, right? If yes, then why not use IF FlagResult = 1 instead of FlagResult <> 0 ?
    Also, as Jerson said, we should see Houston subroutine.
    May be there is something in it that makes things messed up.
  1. Loop with two motor and 2 sensors
  2. Making Program Code Space your playground...
  3. problem with my code
    By civicgundam in forum mel PIC BASIC Pro
    Last Post: - 3rd February 2008, 01:52
  4. Setting code size boundaries
    Last Post: - 8th March 2007, 20:11
  5. Servo Code problem
    By ALFRED in forum General
    Last Post: - 2nd March 2006, 03:30
