Apparent code size problem
Results 1 to 11 of 11
    Sep 2006
    Default Apparent code size problem
    I am having a problem that appears to be related to code size. The chip is 16F917, PBP version is 2.46
    The total code size is over 4000 words Everything compiles and one version of the code works just fine. However a small change is one subroutine to make it more user friendly seems to break eveything. It appears to fail to initialize properly ( based on fact that the opening splash screen never displays and the instrument will not respond to any of the inputs it should immediately after power up). The code is for a company project and so I can not post it all, but I have posted the two code snippets, the total word count of the program when using each variation and the address range
    I encountered this problem once or twice before during this project and both times a change in code size has corrected it. Once was nothing more than adding a line like X = X. This leads me to think it may be some type of boundry issue, but I have to admit I am new enough to PICs and PBP that I am more than a little confused at this time.
    Any help or suggestions would be appreciated.
    The one that works:
    4145 words
    0-1037 address range
    IF (OhmCheck = FAILED) or _ ' resistor out of tolerance or
    (FlagResult <> 0) then ' hardware flag
    GOSUB Houston
    Replace it with this one and it does not work:
    4281 words
    0-10bf address range
    IF OhmCheck = FAILED THEN
    ErrCnt = ErrCnt + 1
    IF ErrCnt = 1 then 'first time gets a pass for a recheck
    Device = DISPLAY
    GOSUB SetCtrl
    LCDOUT $FE,1,"Chk Dckbill conn"
    LCDOUT $FE,$C0,"then retry test"
    PAUSE 1000
    IF (ErrCnt > 1) or (FlagResult <> 0) THEN
    GOSUB Houston
    Bombay, India
    It might have something to do with the gosub Houston routine. Maybe the branch is out of range. You could try to reposition the subroutine Houston and see if it works. I could be totally wrong too...
    Jan 2006
    Istanbul
    Quote Originally Posted by eetech View Post
        GOSUB Houston
    Try this for the one above:
    IF ErrCnt > 1 or FlagResult > 0 THEN GOSUB Houston
       ErrCnt = ErrCnt + 1
          Device = DISPLAY
          GOSUB SetCtrl
          PAUSE 1000
       GOSUB Houston
    And try this for the one above:
    IF OhmCheck = FAILED or FlagResult > 0 then GOSUB Houston
    And try this separately:
        ErrCnt = ErrCnt + 1
            Device = DISPLAY
            GOSUB SetCtrl
            PAUSE 1000
            gosub Houston
    IF FlagResult > 0 THEN GOSUB Houston
    Question: Do you set ErrCnt = 0 before the program starts running, or it gets some values from somewhere else?
    In your code, it seems that it must be set to zero at initial power up before coming to "IF OhmCheck = FAILED THEN" condition.
    Question: FlagResult is a hardware flag. So it can be 1 or 0 only, right? If yes, then why not use IF FlagResult = 1 instead of FlagResult <> 0 ?
    Also, as Jerson said, we should see Houston subroutine.
    May be there is something in it that makes things messed up.
    sinoteq's Avatar
    sinoteq Guest
    Default I think I have seen this before
    What you say looks like something I had some time ago. Check the forum for broken code. http://www.picbasic.co.uk/forum/showthread.php?t=5674
    The problem is when you add a new variable PBP makes a word variable span 2 banks and that is not allowed. If this happens you get "The Harry Potter Syndrome" black magic and nothing is logical anymore. I fixed this for my 18F4620 pic by adding a dummy variable at the last address in each bank. For example:
    bogus_0 VAR BYTE $7F ' force a byte at location 07F
    bogus_1 VAR BYTE $0FF ' force a byte at location 0FF
    bogus_2 VAR BYTE $1FF ' force a byte at location 1FF
    bogus_3 VAR BYTE $2FF ' force a byte at location 2FF
    bogus_4 VAR BYTE $3FF ' force a byte at location 3FF
    bogus_5 VAR BYTE $4FF ' force a byte at location 4FF
    bogus_6 VAR BYTE $5FF ' force a byte at location 5FF
    bogus_7 VAR BYTE $6FF ' force a byte at location 6FF
    bogus_8 VAR BYTE $7FF ' force a byte at location 7FF
    Make sure you get the location right, depending on MCU you should go for different values. Look in the .ASM file for your compiled program and early you will find:
    BANK0_START EQU 00080h
    BANK0_END EQU 000FFh
    BANK1_START EQU 00100h
    BANK1_END EQU 001FFh
    BANK2_START EQU 00200h
    BANK2_END EQU 002FFh
    BANK3_START EQU 00300h
    BANK3_END EQU 003FFh
    Use the END value for you bogus variable and PBP can not make this misstake. Make sure you include BANKA also in the fix.
    Hope this will help to remove Harry Potter from your code. And YES MELABS knows about this because they helped me to find it.
    Mike
    Sep 2006
    Quote Originally Posted by sayzer View Post
        ErrCnt = ErrCnt + 1
            Device = DISPLAY
            GOSUB SetCtrl
            PAUSE 1000
            gosub Houston
    FlagResult is a hardware flag, but it is a set of BIT flags so it can have a result other than 0 or 1.
    Both of those examples are fundamentally the same. The difference being your use of the IF without the ENDIF, which some languages (like PBP) allow.
    I did try it though.
    Yes, ErrCnt is set to 0 before usage.
    The subroutine Houston uses Select Case to decode FlagResult and displays the appropriate error message. It does not return from there but goes into a continous loop because errors that cause Houston to be called are considered critical problems with either the instrument or the site being tested.
    I may not have made myself clear in the original post, the problem does not occur because the code in question is run (the program never gets that far). The problem occurs when the first piece of code is replaced by the second.
    sinoteq's Avatar
    sinoteq Guest
    Default Try the dummy variable fix
    This is what I had, I changed in one place and it died in another. If you check the asm file that you have on the NOT working program it is easy to see. Just look at the end address for each bank and most likely you will see Byte0 of a Word variable there. Byte1 will be in then next bank and this messes up all the RAM area for you even if you don't use that variable in the start of your program.
    M
    Without seeing all of your code it's tough for someone to help debug, but it
    does sound like a page boundary issue.
    If the splash screen never shows on power-up, I'm curious as to where the
    routine that handles this is located? Is it near the end of your program?
    Are you 100% sure you don't have a GOSUB to a sub-routine somewhere with
    a GOTO VS RETURN in the called sub-routine?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Sep 2006
    Default Results so far
    There is one thing I did forget to mention (and I aplogize to all of you that have offered help). The mcu initialization is done in assembly. That code block is located immediately after all the variable declarations, etc.
    Mike,
    I tried the dummy variable fix, it did not cure the problem. after putting the dummies in I checked the address of every word variable in the asm listing to make sure none crossed a page. Here is the asm listing of the page banks and the dummy declarations.
    RAM_START EQU 00020h
    RAM_END EQU 001EFh
    RAM_BANKS EQU 00004h
    BANK0_START EQU 00020h
    BANK0_END EQU 0007Fh
    BANK1_START EQU 000A0h
    BANK1_END EQU 000EFh
    BANK2_START EQU 00120h
    BANK2_END EQU 0016Fh
    BANK3_START EQU 00190h
    BANK3_END EQU 001EFh
    EEPROM_START EQU 02100h
    EEPROM_END EQU 021FFh
    ' Dummy Variable Declarations *
    bogus_0 VAR BYTE $07F
    bogus_1 VAR BYTE $0EF
    bogus_2 VAR BYTE $16F
    bogus_3 VAR BYTE $1EF
    Bruce,
    The code that displays the splash screen is physically located early in the code and is the first code ran once the initializatin sequences are finished.
    I doubled checked my routines, as you suggested, everything ok there.
    I know it is hard to help when you can't see the code, and believe me if I could I would upload the entire project and let everyone have a field day with it.
    The code blocks out like this:
    fuse settings
    defines
    constant declarations
    variable decalrations
    GOTO Start
    INI:
    assembly block (with return) to setup the chip
    Setup:
    routine (with return) to set initial state of variables, etc
    Start:
    GOSUB INI
    GOSUB Setup
    Splash screen is displayed here.
    Some initail instrument checks ( proper hookup, etc) are performed here
    Switch polling routine here
    rest of code body.
    Have you tried replacing your .asm initialization with a BASIC version?
    I know you can sometimes save a few bytes by doing some things in .asm,
    but if you initialize everything in banks PBP doesn't insert a ton of bank
    switching code flipping back & forth between banks. I.E.
    ' Bank0 first
    PORTB = 0
    PORTC = 0
    T2CON = 0
    ' Bank1 next
    TRISA = 0
    TRISB = 0
    CMCON1 = 7, etc, etc,
    Are you using assembler in other routines?
    I would think either something in the INI or Setup routines is causing
    the problem since the splash screen routine is supposed to run directly
    after Setup.
    If one routine is causing the problem, it should be easy to spot.
    Start:
    GOSUB INI
    blink an LED on return to here x times
    GOSUB Setup
    blink an LED on return to here x times, etc, etc,.
    Of course you could always run it through MPSIM too.
    -Bruce
    tech at rentron.com
    Sep 2006
    Bruce,
    I tried the idea of replacing the asm routine with a basic one; pared the program down to just the ini and setup stuff and a display routine. Two versions, one all PBP and the other with the asm block.
    Now... I really feel stupid, the all basic one will not run, the other works just fine. So before I can actually try your idea I now have to figure out what I am doing wrong with the ini code in basic. ( and just in case everyone is wondering at this point... yes, I did write the asm block)
    I have included both below so that anyone who wants ( after they get up off the floor from laughing) can point out my mistake if they would.
    hope I got the code formatting command right so it is easy to read.
    [code]
    ' MCU Setup - inline assembly block *
    INIMCU:
    asm
    bsf STATUS,RP0 ; Select Bank 1
    movlw 07h ; turn off comparators
    movwf CMCON0
    movlw 0xEC ; set A<5,1,0> as digital I/O
    movwf ANSEL ; A<3:2> and E<2:0> as analog
    movlw 0xFF ; set A<7:0> input; (A<3:2> analog; A<7:4,1:0> digital)
    movwf TRISA
    movlw 50h ; set A2D Clock 10h:Fosc/8 50h:Fosc/16
    movwf ADCON1
    movlw 00h ; set PORTB as outputs
    movwf TRISB
    movlw 0xF8 ; set PORTC C<7:3> as inputs; C<2:0> as outputs
    movwf TRISC
    movlw 0x00 ; set PORTD as inputs
    movwf TRISD
    movlw 0Fh ; set PORTE as inputs
    movwf TRISE
    bcf STATUS,RP0 ; Select Bank 2
    bsf STATUS,RP1 ;
    clrf LCDCON ; Disable VLCD<3:1>
    ; inputs on RC<2:0>
    bcf STATUS,RP0 ; Select Bank 0
    bcf STATUS,RP1
    endasm
    ' MCU Setup - PBP
    INIMCU:
    CMCON0 = 7
    ANSEL = $EC
    TRISA = $FF
    ADCON1 = $50
    TRISB = 0
    TRISC = $F8
    TRISD = 0
    TRISE = $0F
    LCDCON = 0
    [\code]
    Bombay, India
    I am wondering if you can do the following. Bruce already suggested this. I am just reminding you of the possibility (to catch a problem) of debugging this technique offers.
    GOTO Start
    INI:
    Setup:
    Start:
       Led = 1:pause 1000:Led = 0
    GOSUB INI
    GOSUB Setup
    rest of code body
    if you see 3 flashes of the led, you have reached the splash screen code.
    Perhaps this will help you find if you are missing a return / stacking too deep. You may have a problem due to the limited caller stack size. Have you looked into this too?
    Jerson
  1. Loop with two motor and 2 sensors
  2. Making Program Code Space your playground...
  3. problem with my code
    By civicgundam in forum mel PIC BASIC Pro
    Last Post: - 3rd February 2008, 02:52
  4. Setting code size boundaries
    Last Post: - 8th March 2007, 21:11
  5. Servo Code problem
    By ALFRED in forum General
    Last Post: - 2nd March 2006, 04:30
