How to send a binary string on an output?
Results 1 to 9 of 9
    Jun 2007
    Germany
    Quote Originally Posted by keithdoxey View Post
    How do you arrive at the values you want to send ?
    I have scanned the signal with a digital scope.
    The output is LOW active. I have split the array to different blocks. Each button if pressed begins with the first string. Look below
    1000000000111110 ' Init sequence (every button)
    110110110110101010110 ' sequence 01
    101011010101010110 ' Instruction for Vol+
    11111111111111111110 ' preparing for 2nd block
    11111111111111111110 ' preparing for 3rd block
    and now the signal stay at HIGH till another button is pressed.
    Many blocks like Init sequence, sequence 01, preparing for next block are in all instruction of each button. Only a few bits are different in the instruction line.
    But this String must be sent as one data without interrupts or delays. Exactly from every bit 1ms.
    Every instruction will be sent 3 times.
    When you will paint same blocks in different colours you will better see, how it works. But itīs not possible to mark with colours
    Feb 2003
    Quote Originally Posted by Robson View Post
    In that case create separate arrays for
    InitSeq
    Seq01
    NextBlock
    Create separate arrays for each command or one large array with all commands and just point to a segment of it eg bits 34-57 (havent worked out the numbers!)
    When you need to send a command just call the component parts as required eg
    SendInitSeq
    SendSeq01
    SendCommand
    SendNextBlock
    SendSeq01
    SendCommand
    SendNextBlock
    SendSeq01
    SendCommand
    The PIC should be able to read and process the values quickly enough not to cause problems, if you see that your output pulses are taking slightly too long then change the pause to pauseus and shorten slightly
    Just add a loop and go round it 3 times. Presumabley there must be some idle time between the 3 instructions so dont forget to add that as a pause
    I pasted it into a text editor and broke it into 4 bit chunks and you can see the patterns you refer to.
    I have built a universal remote control that reads different values from different variables on the fly and that works just fine so I doubt you will have too many problems.
    I seem to remember seeing something by either Darryl or Melanie that showed how you can access individual bits of a byte or word array as well but cant remember where it was eg byte0 was bits 0-7 byte1 was bits 8-15 but I could be wrong.
    Keith
    www.diyha.co.uk
    www.kat5.tv
  1. Active low input?
    By CosMecc in forum mel PIC BASIC Pro
    Last Post: - 8th August 2010, 21:31
  2. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 15:46
  3. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  4. Serious Serial Situation Setbacks...
  5. Visual Basic 6 & Access 2000
    By Demon in forum Off Topic
    Last Post: - 7th September 2006, 05:39
