How to send a binary string on an output?
Results 1 to 9 of 9
    Jun 2007
    Germany
    Quote Originally Posted by keithdoxey View Post
    First thoughts are
    1. declare a bit array of the appropriate size
    2. declare your output pin
    3. set the bits of the array to the desired state
    Then transmit it something like this.....
    For x = 0 to {number_of_bits-1)
        If bitarray[x] = 1 then
            outputpin=1
            outputpin=0
        pause 1 ' wait for 1ms - might need changing for pauseus 990 or similar
    Next
    I might have the state of the pin wrong for your application but you should get the idea
    ok but how to define or declare an array like this?
    bitarray VAR BIT[200]
    bitarray = %1000000000111110110110110110101010110101011010101 01011011111111111111111110110110110110101010110101 01101010101011011111111111111111110110110110110101 0101101010110101010101101
    The compiler returns with "Numeric overflow, value truncated."
    Feb 2003
    How do you arrive at the values you want to send ?
    Are there a series of bytes that you are converting into the binary array ?
    If so declare an array of a suitable number of bytes and set each byte
    eg
    bytearray VAR BYTE[25]
    bytearray[0] = {whatever the value is}
    bytearray[1] = {whatever the next value is}
    etc
    Then transmit those bytes
    For MyByte = 0 to 24
      ThisByte=bytearray[MyByte]
      For MyBit = 0 to 7 ' or 7 to 0 depending on the order !!!!
         If ThisByte.0[MyBit] = 1 then
             OutputPin=1
         Else
             OutputPin=0
         End if
         Pause 1
       Next
    Next
    Without knowing the protocol it is difficult to decide how to set the values.
    Havent tried the code above so offer no guarantee that it would work !!!
    Your question was how to transmit a binary string, not how to create it in the first place
    Dont suppose you have any info on the protocol SONY use for stalk controllers do you ?
    Just wish I could stop my Sony head unit from resetting the iPod EVERY time you turn it on. SWMBOs JVC doesnt.
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Jun 2007
    Germany
    I have scanned the signal with a digital scope.
    The output is LOW active. I have split the array to different blocks. Each button if pressed begins with the first string. Look below
    1000000000111110 ' Init sequence (every button)
    110110110110101010110 ' sequence 01
    101011010101010110 ' Instruction for Vol+
    11111111111111111110 ' preparing for 2nd block
    11111111111111111110 ' preparing for 3rd block
    and now the signal stay at HIGH till another button is pressed.
    Many blocks like Init sequence, sequence 01, preparing for next block are in all instruction of each button. Only a few bits are different in the instruction line.
    But this String must be sent as one data without interrupts or delays. Exactly from every bit 1ms.
    Every instruction will be sent 3 times.
    When you will paint same blocks in different colours you will better see, how it works. But it´s not possible to mark with colours
    Feb 2003
    Quote Originally Posted by Robson View Post
    In that case create separate arrays for
    InitSeq
    Seq01
    NextBlock
    Create separate arrays for each command or one large array with all commands and just point to a segment of it eg bits 34-57 (havent worked out the numbers!)
    When you need to send a command just call the component parts as required eg
    SendInitSeq
    SendSeq01
    SendCommand
    SendNextBlock
    SendSeq01
    SendCommand
    SendNextBlock
    SendSeq01
    SendCommand
    The PIC should be able to read and process the values quickly enough not to cause problems, if you see that your output pulses are taking slightly too long then change the pause to pauseus and shorten slightly
    Just add a loop and go round it 3 times. Presumabley there must be some idle time between the 3 instructions so dont forget to add that as a pause
    I pasted it into a text editor and broke it into 4 bit chunks and you can see the patterns you refer to.
    I have built a universal remote control that reads different values from different variables on the fly and that works just fine so I doubt you will have too many problems.
    I seem to remember seeing something by either Darryl or Melanie that showed how you can access individual bits of a byte or word array as well but cant remember where it was eg byte0 was bits 0-7 byte1 was bits 8-15 but I could be wrong.
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Here's a super easy way to do this. Create command tables
    and simply GOSUB to one & output your command bit-stream.
    This looks-up X directly onto PORTB.0, pauses, then gets the
    next bit.
    X VAR BYTE
    PORTB.0=0 ' set low on boot (change as required here)
    TRISB.0=0 ' RB0 = output
        GOSUB Command1
        GOTO Main
    Command1:
        FOR X = 0 TO 171 ' 172 bits total
        LOOKUP X,[0,0,0,0,0,0,0,0,0,1,1,1,1,1,0,1,1,0,1,1,0,1,1,0,1,1,0,1,0,1,_
                  0,1,0,1,1,0,1,0,1,0,1,1,0,1,0,1,0,1,0,1,0,1,1,0,1,1,1,1,1,1,_
                  1,1,1,1,1,1,1,1,1,1,1,1,1,0,1,1,0,1,1,0,1,1,0,1,1,0,1,0,1,0,_
                  1,0,1,1,0,1,0,1,0,1,1,0,1,0,1,0,1,0,1,0,1,1,0,1,1,1,1,1,1,1,_
                  1,1,1,1,1,1,1,1,1,1,1,1,0,1,1,0,1,1,0,1,1,0,1,1,0,1,0,1,0,1,_
                  0,1,1,0,1,0,1,0,1,1,0,1,0,1,0,1,0,1,0,1,1,0],PORTB.0
         PAUSE 1   ' Note: If this is too long, use PAUSEUS
        NEXT X
    You can have up to 255 entries 'or bits' per table with a 14-bit core device.
    It does eat-up a boat-load of program memory, but it's ultra simple to use.
    Last edited by Bruce; - 26th July 2007 at 00:01. Reason: Changed GOTO Main to RETURN in Command1.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jun 2007
    Germany
    255 Bytes are almost enough.
    Thanks a lot Bruce.
    How´s about the underscores "_" in the array? Need to use them?
    This isn't actually an array. Lookup creates a table, and uses the
    index pointer var (in this case the X) as the offset into the table.
    The underscores are optional. It just looks a lot better than having
    your constant table scrolling WAY off to the right side.
    -Bruce
    tech at rentron.com
  1. Active low input?
    By CosMecc in forum mel PIC BASIC Pro
    Last Post: - 8th August 2010, 21:31
  2. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 15:46
  3. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  4. Serious Serial Situation Setbacks...
  5. Visual Basic 6 & Access 2000
    By Demon in forum Off Topic
    Last Post: - 7th September 2006, 05:39
