Control BH1415 with a 16f88
Results 1 to 10 of 10
    Quote Originally Posted by savnik View Post
    This code is from this : http://people.msoe.edu/~mohre/FinalReport.pdf
    and page 17
    Anyone know how to control this chip (BH1415) ;
    Do you not have the bh1415f datasheet?
    It explains how to set the frequency in there...all easily done with PBP's SHIFTOUT commands...
    bits 0 - 15
    1,0,1,1,1,1,1,1,1,1,0,1,0,0,1,0
    bits 0-10 = frequency, in this case 102.1Mhz
    bit 11 = mode, in this case stereo
    bits 12-13 = phase detector operation, in this case normal
    bits 14-15 = test mode, in this case normal operation
    It's right there on the last 2 pages of the bh1415f datasheet from ROHM.
    Jun 2006
    bits 0 - 15
    I have the bh1415f datasheet and i have read , but i don't know how to send the data to bh1415f , because this chip has data,clock and enable
    For the TSA551 i don't have problem.I have use it many times , but this have only data and clock and use I2CWRITE SDA,SCL,ADDR1,[HI,LO,$8E] to send the data
    SHIFTOUT SHIFTOUT SHIFTOUT SHIFTOUT
    Jun 2006
    I have understand , but i don't have use before the command shiftout.
        Include "modedefs.bas"
    	datapin   var PORTB.0
    	clockpin  var PORTB.1
            enablepin var PORTB.2
        dataout var word
        dataout = %1011111111010010
        high enablepin
        shiftout datapin , clockpin , 0 , [ dataout\16 ]
        low enablepin
    freq var word
    dataout var word
    hardcode var word
    chipselect var portb.0 'or whatever pin you've got set for the chip select
    datapin var portb.1 'or whatever pin you've got set for the data pin
    clockpin var portb.2 'or whatever pin you've got set for the clock pin
    hardcode = %0100100000000000 'hardcoded values - not in test mode, phase detector normal, stereo operation, doesn't (shouldn't?) change
    freq = 1021   'frequency desired = 102.1 Mhz
    dataout = hardcode + freq 'add in frequency value
    high chipselect
    shiftout datapin , clockpin , 0 , [ dataout/16 ]
    low chipselect
    Jun 2006
    freq var word
    dataout var word
    hardcode var word
    high chipselect
    low chipselect
    I test today this code but don't work
  1. How do I give a radio control car autonomous control
    By Kenjones1935 in forum General
    Last Post: - 17th January 2010, 16:40
  2. Problem with 16f88 steep motor control
    By ken_23 in forum Off Topic
    Last Post: - 4th July 2008, 13:25
  3. Control unlimited servos at the same time
    By mrx23 in forum mel PIC BASIC Pro
    Last Post: - 19th September 2006, 15:14
  4. Stepper motor control using PIC 16F88
    By tonykeys in forum mel PIC BASIC Pro
    Last Post: - 3rd February 2006, 21:09
  5. Control RC servo via Parallax Servo Control
    Last Post: - 17th September 2005, 09:18
