See the PBP manual, section 4.7...(may as well look at section 5.40 while you're at it)...
trisa=0:trisb=2:cmcon=7:adcon1=15:adcon0=0:Off_1 var PortA.0:On_1 var PortA.1:Off_2 var PortA.2:On_2 var PortA.3:Speaker var PortA.4:Ground_1 var PortB.0:Positive_1 var PortB.1:Lame_1 var PortB.2
Ground_2 var PortB.3:Positive_2 var PortB.4:Lame_2 var PortB.5:Switch var PortA.5:LED_1 var PortB.6:LED_2 var PortB.7:Positive_Ground_1 var bit:Ground_Lame_1 var bit:Positive_Lame_1 var bit
Positive_Bell_1 var bit:Positive_Ground_2 var bit:Ground_Lame_2 var bit:Positive_Lame_2 var bit:Positive_Bell_2 var bit:PG1_Count var byte:PG2_Count var byte:PL1_Count var byte:PL2_Count var byte
Cal var byte:Lockout var Word:Lockout_Cal var word:On1_Flag var bit:Off1_Flag var bit:On2_Flag var bit:Off2_Flag var bit:cal=18:lockout_cal=373:high on_1: pause 500:low on_1:high off_1: pause 500
low off_1:high off_2: pause 500:low off_2:high on_2: pause 500:low on_2:input lame_1:INPUT LAME_2
Foil:
input positive_1:input positive_2:input ground_1:input ground_2:high positive_1: positive_ground_1=Ground_1: positive_lame_1=lame_2: positive_bell_1=ground_2:low positive_1:input positive_1
input positive_2:input ground_1:input ground_2:high positive_2: positive_ground_2=ground_2: positive_lame_2=lame_1: positive_bell_2=ground_1:low positive_2:input positive_2:high ground_1
ground_lame_1=lame_1:low ground_1:iNPUT GROUND_1:high ground_2:ground_lame_2=lame_2:low ground_2
if positive_ground_1 = 0 and positive_bell_1 = 0 then
pg1_count = pg1_count + 1
pg1_count = 0
if positive_ground_2 = 0 and positive_bell_2 = 0 then
pg2_count = pg2_count + 1
pg2_count = 0
if positive_lame_1 = 1 AND POSITIVE_GROUND_1 = 0 then
pl1_count = pl1_count + 1
pl1_count = 0
if positive_lame_2 = 1 AND POSITIVE_GROUND_2 = 0 then
pl2_count = pl2_count + 1
pl2_count = 0
if pl1_count => cal then
high on_1 : on1_flag = 1
if pl2_count => caL then
high on_2 : on2_flag = 1
if pg1_count => cal AND PL1_COUNT < CAL then
high off_1 : off1_flag = 1
if pg2_count => cal AND PL2_COUNT < CAL then
high off_2 : let off2_flag = 1
LED_1 = GROUND_LAME_1 : LED_2 = GROUND_LAME_2
if On1_flag = 1 or off2_flag = 1 or on2_flag = 1 or off1_flag = 1 then
lockout = lockout + 1
lockout = 0
if lockout => lockout_cal then
pause 2000 : low on_1 : low on_2 : low off_1 : low off_2 : on1_flag = 0 : on2_flag = 0 : off1_flag = 0 : off2_flag = 0
goto foil
