Multiple IF-THEN statements
Results 1 to 12 of 12
    Jun 2006
    California
    Default Multiple IF-THEN statements
    I know it is late and maybe that is the problem. I am trying to run multiple IF-THEN statements. Individually they work fine, but combining them does not. The combined statements assemble fine. BTW, I am reading a clock chip and after every minute rollover, I cycle a cooling fan approx 7 seconds at the 0 second point and 30 second point. I may have to adjust this time (or increase the number of cycles) so I want to be flexible. Where am I missing it?
    IF (rtcsec >= $00) AND (rtcsec <= $07) THEN
    portb.7 = 1
    IF (rtcsec >= $30) AND (rtcsec <= $37) THEN
    portb.7 = 1
    portb.7 = 0
    Jan 2006
    Istanbul
    try this;
    IF rtcsec <= $07 OR (rtcsec >= $30 AND rtcsec <= $37) THEN
       portb.7 = 1
       portb.7 = 0
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Quote Originally Posted by DavidK View Post
    portb.7 = 1
    portb.7 = 1
    portb.7 = 0
    Here is why yours did not work - all I did was format your IF-Thens
    	portb.7 = 1
    		portb.7 = 1
    		portb.7 = 0
    As you can see in order for the code to reach your between 30-37 check, the first condition must be true (between 0-7) - go with Jerson's version or two separate checks like you said you had working.
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Jan 2006
    Istanbul
    Quote Originally Posted by paul borgmeier
    .... - go with Jerson's version ...
    Who is Jerson ?
    Post one test only version ...
    May be we could simplify ...
    RTCSEC is ALWAYS >= 0 with PbP ... huh ...
    IF ( RTCSEC & $F0) = 0 or 3 ... AND
    IF RTCSEC & $0F < 8 ... PortB.7 = 1
    Else Portb.7 = 0
    so,
    IF (( rtcsec & $F0 = 0 ) OR (rtcsec & $F0 = $30 )) AND ( rtcsec & $0F < 8 ) THEN
    PORTB.7 = 1
    PORTB.7 = 0
    PS: Hi Sayzer ... you've also got one point !!!
    Feb 2003
    Red face
    Quote Originally Posted by sayzer View Post
    Who is Jerson ?
    MY apologies - Please substitute Sayzer for Jerson. That is what staying up to 4AM gets me. Jerson regularly contributes and for some reason, I mixed you up when I was writing my reply? (I hope neither of you are offended by that - if you are, next time either of you are in SLC, UT, I will by you a beer or a beverage of your choice).
    Paul
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Bombay, India
    Who is Jerson ?
    Hey, that's me. No offence taken Paul. I am in a way lucky to be entitled to one of your free beers/beverages. Thanks.
    Jerson
    Jan 2006
    Istanbul
    Quote Originally Posted by paul borgmeier View Post
    ...Please substitute Sayzer for Jerson. ...
    Paul
    Which one is correct ?
    "Please substitute Sayzer for Jerson" OR "Please substitute Jerson for Sayzer ".
    I am confused a little there.
    Is it something with my English or my understanding?
    P.S. - Not offended of any kind...
    IF A=B... will B=A ?
    Jun 2006
    California
    Talking
    WOW !! That simple. I was real foggy last night. Tried the code suggestion and it works perfect. Now hopefully I can get by with just two cooling’s otherwise I have to install a temperature sensor, wich I might do anyway. Fans make noise.
    Thanks everyone for your help and explanations
  1. Multiple PICS from Same Crystal?
    By WOZZY-2010 in forum General
    Last Post: - 6th February 2010, 15:18
  2. Multiple RETURNS within a single subroutine
    Last Post: - 21st June 2009, 16:43
  3. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  4. Multiple SERIN's
    By JoeR in forum mel PIC BASIC
    Last Post: - 6th October 2005, 22:22
  5. Multiple IR LEDs from 1 port using transistor
    By belpe123 in forum General
    Last Post: - 20th May 2005, 22:07
