Some Minor Setup Issues
Results 1 to 3 of 3
    pbMac's Avatar
    pbMac Guest
    Default Some Minor Setup Issues
    OS: Win98 SE
    Install Location: c:\pbp
    Problem:
    PBRegister.bat error message "bad command or filename", both Suite_PicBasicPro.dll and Suite_PicBasic.dll are in c:\pbp along with the batch file. Any Ideas? Can I edit the registry manually, if so what does the data look like, or is it too much. Any help is appreciated. Using MPLab 7.60 as well.
    Quote Originally Posted by pbMac View Post
    OS: Win98 SE
    Problem:
    Did you follow the instructions for changing the Path statement in the autoexec.bat file as noted on melabs support page?
    No autoexec.bat stuff but Local variable environment
    http://www.melabs.com/support/mplab.htm
    You could still try to register them manually with regsvr32 PBPSUITE.DLL but first you need to make sure this file is located in Windows\system32 folder.
    Sure you'll need to change the Environment variable as well, make sure the language toolsuite executable is selected and placed in the right folder.
    Reboot the system, and enjoy.. or cry
  1. SERIN2 buffer issues...
    Last Post: - 16th October 2008, 04:49
  2. Solved: notes on annoying little issues
    By Probotics in forum mel PIC BASIC Pro
    Last Post: - 26th May 2008, 21:02
  3. Where should I discuss SD/MMC FAT issues?
    By JD123 in forum General
    Last Post: - 2nd April 2008, 22:41
  4. I2C Master Slave issues.
    Last Post: - 29th March 2008, 20:33
  5. Circuit reliability issues
    By hkpatrice in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2007, 15:55
