See if I got this straight:
You have now:
Sensor minimum 1.8v - maximum 5v
(PIC A/D minimum 0v - maximum 5v)
You want to shift the input down by 1.8v, so a zero input is really a ZERO input, then you want to multiply that input by 1.5625 so you can regain the full range of 0-5v at the A/D input?
You could do all the above...but, yes, you can reference the Vref- to 1.8v giving you a new ZERO (0) at the A/D input, and use 5v for Vref+ giving you MAX (1023 for 10bit A/D) at the A/D input of the PIC. You could use something as simple as 3 silicon diodes in series or even a red led (hand picked parts of course) as this would give you the 1.8v needed for Vref-. Of course the Vf would vary a bit, temperature, etc. But using the red led would also give you a power led.
And what is this sensor? How much accuracy do you REALLY need?
