PIC AD + Vref- using external IC
Results 1 to 7 of 7
    Nov 2004
    Default PIC AD + Vref- using external IC
    I have been using the AD on a 16f877A with no problems till now , but at the present , in order to change the AD resolution , I need to use the Vref- ( 0 is will not be zero /Vss , but will be 1.8v …) As so , I have been wandering around for a good stabilised Vref of 1.8 to connect to my Vref - ….Any suggestion , advices ? Any good and cheap IC you have been using to get similar V ref outputs?
    Note: as you know the standard V divisor using R is really not good, fluctuates a lot, so this hint is out of the deck ;-) .
    Thanks for any help!
    Jorge
    Wink The Horrible word !!!
    Hi, Jorge
    Did you , eventually, had a look to the PIC datasheet ... chapter 13 ( you know, the good luck number ... )
    To be clear , at what is called, CVRef PIN ...
    Nov 2004
    Default Vref- and AD ...manual =?
    i may be missing something ..but in my manual chapter 13 is instruction set summary ...and the one for the AD is the chapter 11...
    I saw both...but i really dont know what are you leading me in :-) ?
    BTW , i also believe in always RTFM :-) ...
    I will explain better my problem , my sensor always outputs ( in standby status 1.8v , and it increases like 0.2mv until it reaches the 5v - since i am using the AD with 0 to 5v refs, and so i make a simple offset routine to "reset it" but ...this way i am only able to read it to 5v ..losing the "end part output above 5v ” ...so what i am trying to do is starting in 1.8 as 0 and going til "5+1.8 v" .... am i messing it up or thinking like a drunk guy ? cant I use an external IC to give to pin Vref- an V- reference different than 0 ?
    i know i could workout with some opamps and rescale it ...but i thought i could be able to use Vref- to an voltage reference IC to achieve this ?!?
    thanks.
    Hi, Jorge
    See if I got this straight:
    You have now:
    Sensor minimum 1.8v - maximum 5v
    (PIC A/D minimum 0v - maximum 5v)
    You want to shift the input down by 1.8v, so a zero input is really a ZERO input, then you want to multiply that input by 1.5625 so you can regain the full range of 0-5v at the A/D input?
    You could do all the above...but, yes, you can reference the Vref- to 1.8v giving you a new ZERO (0) at the A/D input, and use 5v for Vref+ giving you MAX (1023 for 10bit A/D) at the A/D input of the PIC. You could use something as simple as 3 silicon diodes in series or even a red led (hand picked parts of course) as this would give you the 1.8v needed for Vref-. Of course the Vf would vary a bit, temperature, etc. But using the red led would also give you a power led.
    And what is this sensor? How much accuracy do you REALLY need?
    lm4128, LM4132 are nice. more you pay, more they're accurate.
    Nov 2004
    Default IC to Vref ...
    Thanks , i will try them !
    Nov 2004
    You have now:
    Hi, first of all thanks for you reply.
    Regarding the sensor it ´s a pressure sensor. And regarding the reason , it is simple: since i am discarding by software the first 1.8v of the 5v AD readings i am loosing almost ~36% of the pressure range i could obtain -> 1.8v to 5v only !!!...3.2v only to be converted into valid/useful steps of the AD!
    Thanks again for the LED hint , but i really need a Temp free device...
  1. PIC 12c509 - No External timing components
    By stay_aliveuk in forum mel PIC BASIC Pro
    Last Post: - 8th September 2006, 17:20
  2. External UART IC
    By Terry in forum General
    Last Post: - 22nd December 2005, 18:01
  3. question regarding an external AD converter
    By dtoohey in forum mel PIC BASIC Pro
    Last Post: - 15th March 2005, 05:50
  4. Serial Pic to Pic using HSER
  5. switching external vref+ and vdd vref
    By alejandro_halon in forum mel PIC BASIC Pro
    Last Post: - 16th February 2005, 20:13
