PIC16F84A EEPROM problems
Results 1 to 24 of 24
    Quote Originally Posted by The Master View Post
    Heres a cut down sample of my program
    taddress var byte
    taddress=20
    write 0,taddress
    That code snip really doesn't tell us anything. Post the whole thing. You've got a DEFINE wrong somewhere, maybe some conflicting interrupts, who knows...
    Maybe change the handle from 'The Master' to 'Maybe the Master in the Future, but for now, I can't get a simple EEPROM write to work'...
    May 2006
    Kedah, Malaysia
    Maybe he is master in other field.
    Jun 2007
    Mansfield, UK
    Quote Originally Posted by fazan83 View Post
    too right :P thats my name on other forums. just keeping it the same. im good at VB6 etc
    ive not defined anything so far and ive not got any interrupts. the example i saw on the net didnt say to define anything
    http://www.microengineeringlabs.com/...les/pbc/ee.bas
    everything else in the program works fine. all the serin/serout if then elses etc. its just read/write that dont work
    Jun 2007
    Mansfield, UK
    righty. now im at home i can give you th full code. i made an new test program and it still doesnt work
    trisa=%00000000
    trisb=%00000000
    t1 var byte
    high portb.0
    low portb.0
    high portb.3
    low portb.3
    read 0,t1
    portb=t1
    it has 8 LEDs connected to portb. 2 of them flash on startup to prove the chip is working then it should read a value from EEPROM[0] and display it using the LEDs.
    i set the EEPROM values in the programmer software before programming. if i read everything back from the chip then i can see it definately has set the EEPROM.
    no matter what value i put in the EEPROM the LEDs always tell me the value is %11111110
    Instead of END, try STOP, or a read/portb/goto loop, see what happens.
    Do you have anything across Vss & Vdd?
    Jun 2007
    Mansfield, UK
    i tried the loop
    loop:
    read 0,t1
    portb=t1
    goto loop
    still same result.
    what might i have accross vss and vdd? do you mean power or components? i have power because the LEDs work. i also have a capacitor before the regulator or the chip wont work
    How about a little something, like a .1uf across Vdd and Vss on the PIC itself?
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 15:46
  2. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 04:17
  3. Problems with driving external EEPROM M24256
    By Kristjan in forum mel PIC BASIC Pro
    Last Post: - 10th February 2008, 12:34
  4. How to write/read strings EEPROM/LCD
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 07:26
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 20:59
