PIC16F84A EEPROM problems
Results 1 to 24 of 24
    Jun 2007
    Mansfield, UK
    ok, i copied that exactly. it wouldnt compile because of the top line so i removed it and set the fuses in the programmer software. i borrowed one of those caps from another circuit and its still not working. im getting the exact same result
    Edit: MCLR is connected to vdd with a 10K resistor
    OK, so what happen if you change the loop to
            for Addr=0 to 7
                PORTB = DCD ADDR
                PAUSE 500
                NEXT
    If it doesn't work... or you have a faulty crystal, or your crystal capacitor are bad, or the PSU is bad, or the PIC is bad... OR everything previously listed
    EDIT: config fuses..
    Jun 2007
    Mansfield, UK
    [QUOTE=mister_e;39699]OK, so what happen if you change the loop to
            for Addr=0 to 7
                PORTB = DCD ADDR
                PAUSE 500
                NEXT
    that works. the LEDs are chasing as expected. what does this mean then?
    Probably the PIC EEPROM is bad OR there's a setting in your device programmer software that you overlooked.
    What i mean is that some Device programmer software allow to program OR NOT the PIC EEPROM. Sure it's something like that.
    Jun 2007
    Mansfield, UK
    right. ive just tested it on another chip so its not that. theres 1 more fuse value you didnt mention so i changed that. the programmer app has an EEPROM override button so i tried that too and still as before.
    this is confusing. random thought, could this possibly be anything like those chips where you have to access the *internal* EEPROM asif it was *external*?
    another thing is that the datasheet for this chip says EEPROM stuff has to be written in a certain way but it only gives examples of assembly code so i dont understand it
    compile the first example the send me the generated .HEX file (in a .ZIP)
    Everything work as expected here.
    Which PIC programmer and software do you use?
    EDIT: Which PBP version ?
    Jun 2007
    Mansfield, UK
    ok, this is the first example without the first line (or it wont compile)
    the programmer i think is DIY K149 or 3149B-E
    the programmer software is micropro25
    Edit: Microcode studio 2.2.11 / PICBASIC PRO 2.45
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 15:46
  2. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 04:17
  3. Problems with driving external EEPROM M24256
    By Kristjan in forum mel PIC BASIC Pro
    Last Post: - 10th February 2008, 12:34
  4. How to write/read strings EEPROM/LCD
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 07:26
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 20:59
