Thanks for the post
I correct them, but it still doesn't work.
Thanks for the post
I don't read your language, but I get the idea of the program (I think)...a few problems noted, no enable in the program for the interrupts, moved some blocks around, did some re-writing of the code...check it out.
Code:DEFINE OSC 4 DEFINE I2C_HOLD 1 Define LCD_DREG PORTB 'LCD definialasa Define LCD_DBIT 4 'kezdo adatbit Define LCD_RSREG PORTB 'PORTB.3:RSbit Define LCD_RSBIT 3 Define LCD_EREG PORTB 'Ebit:PORTB.2 Define LCD_EBIT 2 Define LCD_BITS 4 'LCD bus meret Define LCD_LINES 2 '2 soros Buttontemp var Byte:h var Byte:b var byte:c var byte:t var byte:m1 var byte:m2 var byte:m3 var byte:m4 var byte:mb1 var byte:mb2 var byte:mt1 var byte mt2 var byte:d1 var byte:I2Cdev var byte:SDA var PORTC.4:SCL var PORTC.3:I2Caddr var word goto skip_on_int On interrupt goto delay_5s 'megszakitasi rutin disable 'megszakitas felfüggesztese delay_5s: d1=d1+1:INTCON.2=0 if d1>77 then '5s=5000ms=65ms*77 d1=0:INTCON=0 : goto kiirhe 'hangero kiirasa endif 'ha nem,vissza resume enable skip_on_int: m1=0:m2=$40:m3=$80:m4=$c0:TRISC=$e7:TRISD=$f:TRISA=0:TRISB=0:I2Cdev=$50:I2Caddr=0:h=0:b=0:c=31:t=31:PORTA=63:high portd.4:ADCON0=0:ADCON1=7:CMCON=7:SSPCON=0 pause 500:lcdout $fe,1:pause 100:lcdout " Udvozollek":pause 200:I2CWRITE SDA,SCL,I2Cdev,I2Caddr,[$1f,$5f,$9f,$df]:pause 100:OPTION_REG=7:INTCON=$a0 '*************************** A foprogram ***************************** main: button PORTC.1,0,0,0,buttontemp,1,novelhe:button PORTC.6,0,0,0,buttontemp,1,csokkenthe:button PortC.5,0,0,0,buttontemp,1,bemnov button PORTd.3,0,0,0,buttontemp,1,bemcsokk:button PORTC.0,0,0,0,buttontemp,1,bassn:button PORTD.1,0,0,0,buttontemp,1,basscs button PORTc.7,0,0,0,buttontemp,1,tren:button PORTd.2,0,0,0,buttontemp,1,trecs:Goto main '****************** A hangero-szabalyozo rutinjai ******************** novelhe: if h<63 THEN h = h + 1 if ( h < 16 ) OR ( h > 31 and h < 48 ) then portA = h + 16 : goto kiirhe endif if ( h > 15 and h < 32 ) OR ( h > 47 and h < 64) then porta = h - 16 : goto kiirhe endif Goto kiirhe csokkenthe: if h>0 then h= h - 1 if ( h < 16 ) OR ( h > 31 and h < 48 ) then portA = h + 16 : goto kiirhe endif if ( h > 15 and h < 32 ) OR ( h > 47 and h < 64) then porta = h - 16 : goto kiirhe endif Goto kiirhe '******************** A hangszinszabalyozo rutinjai ****************** bassn: if c<63 THEN c = c + 2 mb1=c & m1:mb2=c & m4:I2CWRITE SDA,SCL,I2Cdev,I2Caddr,[mb1,mb2]:pause 200:goto kiirmely basscs: if c>1 then c= c - 2 mb1 = c & m1:mb2 = c & m4:I2CWRITE SDA,SCL,I2Cdev,I2Caddr,[mb1,mb2]:pause 200:goto kiirmely tren: if t<63 THEN t = t + 2 mt1 = t & m2:mt2 = t & m3:I2CWRITE SDA,SCL,I2Cdev,I2Caddr,[mt1,mt2]:Pause 200:goto kiirmely trecs: if t>1 THEN t = t - 2 mt1 = t & m2:mt2 = t & m3:I2CWRITE SDA,SCL,I2Cdev,I2Caddr,[mt1,mt2]:Pause 200:goto kiirmely '************************ A hangero cimkei *************************** 'replaced as shown above '************************ A hangero kiiratasa ************************ kiirhe: lcdout $fe,1:pause 100:lcdout " Hangero: ",#h:pause 250:b=b+1:lcdout $fe,$c0:pause 100:lcdout " Bemenet: ",#b:pause 250:b=b-1:goto main '*********************** A dB-ertekek kiiratasa ********************** kiirmely: mb1=0:mb2=0 LOOKUP c,[0,20,0,15,0,9,0,8,0,7,0,6,0,5,0,4,0,4,0,3,0,2,0,2,0,1,0,1,0,0,0,0,0,0,0,1,0,1,0,2,0,2,0,3,0,4,0,4,0,5,0,6,0,7,0,8,0,9,0,15,0,20,0,20],mb1 LOOKUP c,[0,0,0,0,0,8,0,4,0,3,0,3,0,5,0,6,0,0,0,4,0,8,0,2,0,6,0,0,0,5,0,0,0,5,0,0,0,6,0,2,0,8,0,4,0,0,0,6,0,5,0,3,0,3,0,4,0,8,0,0,0,0,0,0],mb2 if c<32 then kiirmep 'pozitiv ertek eseten if c>32 then kiirmen 'negativ eseten kiirmen: lcdout $fe,1:pause 100:lcdout " Mely: ","-",#mb1,",",#mb2,"dB":goto kiirmag kiirmep: lcdout $fe,1:pause 100:lcdout " Mely: "," ",#mb1,",",#mb2,"dB":goto kiirmag kiirmag: pause 250 : mb1=0:mb2=0 LOOKUP t,[0,20,0,15,0,9,0,8,0,7,0,6,0,5,0,4,0,4,0,3,0,2,0,2,0,1,0,1,0,0,0,0,0,0,0,1,0,1,0,2,0,2,0,3,0,4,0,4,0,5,0,6,0,7,0,8,0,9,0,15,0,20,0,20],mb1 LOOKUP t,[0,0,0,0,0,8,0,4,0,3,0,3,0,5,0,6,0,0,0,4,0,8,0,2,0,6,0,0,0,5,0,0,0,5,0,0,0,6,0,2,0,8,0,4,0,0,0,6,0,5,0,3,0,3,0,4,0,8,0,0,0,0,0,0],mb2 if t<32 then kiirmap if t>32 then kiirman kiirman: lcdout $fe,$c0:pause 100:lcdout " Magas: ","-",#mb1,",",#mb2,"dB":pause 250:TMR0=0:d1=0:INTCON=%10100000:goto main kiirmap: lcdout $fe,$c0:pause 100:lcdout " Magas: "," ",#mb1,",",#mb2,"dB":pause 250:TMR0=0:d1=0:INTCON=%10100000:goto main '********************* A bemenetvalaszto rutinjai ******************** bemnov: if b<3 then b=b+1 goto new1 bemcsokk: if b>0 then b=b-1 goto new1 new1: low portd.7:low portd.6:low portd.5:low portd.4 : high portd.0[ bem + 4 ] : goto kirrhe '********************** 5 masodperces delay rutin ******************* 'moved to near start of program End
Thank you very much
But the "I2CWRITE" still don't work, the potentiometer value not change.
Is this the first time you've tried using this particular IC?
I've said it before, I'll say it again, start simple, work your way up...
How do you really know that the value is supposed to change? How do you really know that your interrupts are being handled the way you want them to be handled?
Replace the I2CWRITE commands with writes to the LCD, make sure you're logic is working, don't worry about what the chip does, just watch your numbers, see what they do first. Rewrite your program to write various values to the chip and the LCD and make sure the chip follows what you really want to do. Then integrate everything together. For all you know, there's something fundamentally wrong with the way you wrote the program.
Yes, it is the first time with this IC.
The hardware is ready , everything function functionate , excepting the I2C.
The LCD writes the right value, the interrupt also well functionate.
The trouble is that between the potentiometer outputs not mensurable the tuned worth. When there is off , here mensurable the 100k, run during wrongly the value.
excuse for my english
thanks
Try this out. If it works, it's up to you to figure out what's different...
(and your English is fine, not perfect, but fine...and certainly a lot better than my ___________(<-insert language here).)
DEFINE I2C_HOLD 1
Define LCD_RSBIT 3
Define LCD_EBIT 2
buttontemp var byte : h var byte : b var byte : c var byte : t var byte : m1 var byte : m2 var byte : m3 var byte : m4 var byte : mb1 var byte : mb2 var byte
mt1 var byte : mt2 var byte : d1 var byte : i2cdev var byte : sda var portc.4 : scl var portc.3 : goto skip_on_int
delay_5s: d1=d1+1 : INTCON.2=0
d1=0 : INTCON=0 : goto kiirhe 'hangero kiirasa
resume
enable
skip_on_int:
m1=0 : m2=$40 : m3=$80 : m4=$c0 : trisc=$e7 : trisd=$f : trisa=0 : trisb=0 : i2cdev=$50 : h=0 : b=0 : c=31 : t=31 : porta=63 : high portd.4 : adcon0=0
adcon1=7 : cmcon=7 : sspcon=0 : pause 500 : lcdout $fe,1," Udvozollek" : pause 200 : i2cwrite sda,scl,i2cdev,[$1f,$5f,$9f,$df] : pause 100 : option_reg=7
intcon=$a0
main: button PORTC.1,0,0,0,buttontemp,1,novelhe : button PORTC.6,0,0,0,buttontemp,1,csokkenthe : button PortC.5,0,0,0,buttontemp,1,bemnov
button PORTd.3,0,0,0,buttontemp,1,bemcsokk : button PORTC.0,0,0,0,buttontemp,1,bassn : button PORTD.1,0,0,0,buttontemp,1,basscs
button PORTc.7,0,0,0,buttontemp,1,tren : button PORTd.2,0,0,0,buttontemp,1,trecs : Goto main
Goto kiirhe
Goto kiirhe
mb1=c & m1 : mb2=c & m4 : i2cwrite sda,scl,,i2cdev,[mb1,mb2] : pause 200 : goto kiirmely
mb1=c & m1 : mb2=c & m4 : i2cwrite sda,scl,i2cdev,[mb1,mb2] : pause 200 : goto kiirmely
mt1=t & m2 : mt2=t & m3 : i2cwrite sda,scl,i2cdev,[mt1,mt2] : Pause 200 : goto kiirmely
kiirhe: lcdout $fe,1," Hangero: ",#h : pause 250 : b=b+1 : lcdout $fe,$c0," Bemenet: ",#b : pause 250 : b=b-1 : goto main
kiirmely: mb1=0 : mb2=0
LOOKUP c,[0,20,0,15,0,9,0,8,0,7,0,6,0,5,0,4,0,4,0,3,0,2,0,2, 0,1,0,1,0,0,0,0,0,0,0,1,0,1,0,2,0,2,0,3,0,4,0,4,0, 5,0,6,0,7,0,8,0,9,0,15,0,20,0,20],mb1
LOOKUP c,[0,0,0,0,0,8,0,4,0,3,0,3,0,5,0,6,0,0,0,4,0,8,0,2,0, 6,0,0,0,5,0,0,0,5,0,0,0,6,0,2,0,8,0,4,0,0,0,6,0,5, 0,3,0,3,0,4,0,8,0,0,0,0,0,0],mb2
kiirmen: lcdout $fe,1," Mely: ","-",#mb1,",",#mb2,"dB":goto kiirmag
kiirmep: lcdout $fe,1," Mely: "," ",#mb1,",",#mb2,"dB":goto kiirmag
kiirmag: pause 250 : mb1=0 : mb2=0
LOOKUP t,[0,20,0,15,0,9,0,8,0,7,0,6,0,5,0,4,0,4,0,3,0,2,0,2, 0,1,0,1,0,0,0,0,0,0,0,1,0,1,0,2,0,2,0,3,0,4,0,4,0, 5,0,6,0,7,0,8,0,9,0,15,0,20,0,20],mb1
LOOKUP t,[0,0,0,0,0,8,0,4,0,3,0,3,0,5,0,6,0,0,0,4,0,8,0,2,0, 6,0,0,0,5,0,0,0,5,0,0,0,6,0,2,0,8,0,4,0,0,0,6,0,5, 0,3,0,3,0,4,0,8,0,0,0,0,0,0],mb2
kiirman: lcdout $fe,$c0," Magas: ","-",#mb1,",",#mb2,"dB" : pause 250 : TMR0=0 : d1=0 : INTCON=%10100000 : goto main
kiirmap: lcdout $fe,$c0," Magas: "," ",#mb1,",",#mb2,"dB" : pause 250 : TMR0=0 : d1=0 : INTCON=%10100000 : goto main
goto new1
goto new1
new1: low portd.7 : low portd.6 : low portd.5 : low portd.4 : high portd.0[bem+4] : goto kirrhe
Thanks for the post
Unfortunately that way nor functionate. Already I've tried with one other DS1844 also , but nothing change. Already everything run-through on several occasions , but nothing make mistake not I had found.
You may have a trace problem or breadboard problem. Check with a meter.
Tim
Yes, I have 4,7k pull-up resistors
Already I've tried check, but I hadn't found nothing mistake.
Yet I will to try
