I2C problem (16F877A with DS1844)
Results 1 to 12 of 12
    Jun 2007
    Default I2C problem (16F877A with DS1844)
    Hi!
    I am working on a digital amplifier project with DS1844 digipot but the I2C communication don't work.
    I use PIC16F877A, SCL is PORTC.3 and SDA PORTC.4 with 10k pull-up resistors. (also I tried with 4,7k)
    The control byte is 01010000, A0, A1, A2=0; PS=1
    The program:
    TRISC = %11100111 'bemenetek beallitasa
    TRISD = %00001111
    TRISA = 0
    TRISB = 0
    SDA var PORTC.4
    SCL var PORTC.3
    DEFINE I2C_HOLD 1
    ADCON0=0
    ADCON1=7 'ADC kikapcsolva
    CMCON=7 'komparator ki
    SSPCON=0
    Define LCD_DREG PORTB 'LCD definialasa
    Define LCD_LINES 2 '2 soros
    I2CWRITE SDA, SCL, %01010000, 0, [%00011111, %01011111, %10011111, %11011111]
    I was tried it in many ways, but not work.
    excuse for my english
    thanks
    lissajous from Hungary
    Jun 2006
    Im not very familiar with I2C, however I remember seeing this:
    http://www.picbasic.co.uk/forum/show...light=i2cwrite
    See the first point, 'Do you have any CONSTANTS in the device address?'
    Jun 2007
    Default Re
    Thanks for the post
    I correct them, but it still doesn't work.
    Quote Originally Posted by lissajous View Post
    Thanks for the post
    I don't read your language, but I get the idea of the program (I think)...a few problems noted, no enable in the program for the interrupts, moved some blocks around, did some re-writing of the code...check it out.
    DEFINE I2C_HOLD 1
    Define LCD_DBIT 4		'kezdo adatbit
    Define LCD_RSREG PORTB		'PORTB.3:RSbit
    Define LCD_RSBIT 3
    Define LCD_EREG PORTB		'Ebit:PORTB.2
    Define LCD_EBIT 2
    Define LCD_BITS 4		'LCD bus meret
    Buttontemp var Byte:h var Byte:b var byte:c var byte:t var byte:m1 var byte:m2 var byte:m3 var byte:m4 var byte:mb1 var byte:mb2 var byte:mt1 var byte
    mt2 var byte:d1 var byte:I2Cdev var byte:SDA var PORTC.4:SCL var PORTC.3:I2Caddr var word
    goto skip_on_int
    On interrupt goto delay_5s	'megszakitasi rutin
    disable			'megszakitas felfüggesztese
    delay_5s:	d1=d1+1:INTCON.2=0
    	if d1>77 then 		'5s=5000ms=65ms*77
    		d1=0:INTCON=0	: goto kiirhe		'hangero kiirasa
    	endif			'ha nem,vissza
    	resume
    enable
    skip_on_int:
    m1=0:m2=$40:m3=$80:m4=$c0:TRISC=$e7:TRISD=$f:TRISA=0:TRISB=0:I2Cdev=$50:I2Caddr=0:h=0:b=0:c=31:t=31:PORTA=63:high portd.4:ADCON0=0:ADCON1=7:CMCON=7:SSPCON=0
    pause 500:lcdout $fe,1:pause 100:lcdout "   Udvozollek":pause 200:I2CWRITE SDA,SCL,I2Cdev,I2Caddr,[$1f,$5f,$9f,$df]:pause 100:OPTION_REG=7:INTCON=$a0
    '*************************** A foprogram *****************************
    main:	button PORTC.1,0,0,0,buttontemp,1,novelhe:button PORTC.6,0,0,0,buttontemp,1,csokkenthe:button PortC.5,0,0,0,buttontemp,1,bemnov
    	button PORTd.3,0,0,0,buttontemp,1,bemcsokk:button PORTC.0,0,0,0,buttontemp,1,bassn:button PORTD.1,0,0,0,buttontemp,1,basscs
    	button PORTc.7,0,0,0,buttontemp,1,tren:button PORTd.2,0,0,0,buttontemp,1,trecs:Goto main
    '****************** A hangero-szabalyozo rutinjai ********************
    novelhe:	if h<63 THEN h = h + 1
    	if ( h < 16 ) OR ( h > 31 and h < 48 ) then
    		portA = h + 16 : goto kiirhe
    	if ( h > 15 and h < 32 ) OR ( h > 47 and h < 64) then
    		porta = h - 16 : goto kiirhe
    	Goto kiirhe
    csokkenthe:	if h>0 then h= h - 1
    	Goto kiirhe
    '******************** A hangszinszabalyozo rutinjai ******************
    bassn:	if c<63 THEN c = c + 2
    	mb1=c & m1:mb2=c & m4:I2CWRITE SDA,SCL,I2Cdev,I2Caddr,[mb1,mb2]:pause 200:goto kiirmely
    basscs: if c>1 then c= c - 2
    	mb1 = c & m1:mb2 = c & m4:I2CWRITE SDA,SCL,I2Cdev,I2Caddr,[mb1,mb2]:pause 200:goto kiirmely
    tren:	if t<63 THEN t = t + 2
    	mt1 = t & m2:mt2 = t & m3:I2CWRITE SDA,SCL,I2Cdev,I2Caddr,[mt1,mt2]:Pause 200:goto kiirmely
    trecs:	if t>1 THEN t = t - 2
    '************************ A hangero cimkei ***************************
    'replaced as shown above
    '************************ A hangero kiiratasa ************************
    kiirhe:	lcdout $fe,1:pause 100:lcdout "  Hangero:  ",#h:pause 250:b=b+1:lcdout $fe,$c0:pause 100:lcdout "  Bemenet:  ",#b:pause 250:b=b-1:goto main
    '*********************** A dB-ertekek kiiratasa **********************
    kiirmely:	mb1=0:mb2=0
    LOOKUP c,[0,20,0,15,0,9,0,8,0,7,0,6,0,5,0,4,0,4,0,3,0,2,0,2,0,1,0,1,0,0,0,0,0,0,0,1,0,1,0,2,0,2,0,3,0,4,0,4,0,5,0,6,0,7,0,8,0,9,0,15,0,20,0,20],mb1
    LOOKUP c,[0,0,0,0,0,8,0,4,0,3,0,3,0,5,0,6,0,0,0,4,0,8,0,2,0,6,0,0,0,5,0,0,0,5,0,0,0,6,0,2,0,8,0,4,0,0,0,6,0,5,0,3,0,3,0,4,0,8,0,0,0,0,0,0],mb2
    	if c<32 then kiirmep			'pozitiv ertek eseten
    	if c>32	then kiirmen			'negativ eseten
    kiirmen: 	lcdout $fe,1:pause 100:lcdout " Mely:  ","-",#mb1,",",#mb2,"dB":goto kiirmag
    kiirmep:	lcdout $fe,1:pause 100:lcdout " Mely:  "," ",#mb1,",",#mb2,"dB":goto kiirmag
    kiirmag:	pause 250 : mb1=0:mb2=0
    LOOKUP t,[0,20,0,15,0,9,0,8,0,7,0,6,0,5,0,4,0,4,0,3,0,2,0,2,0,1,0,1,0,0,0,0,0,0,0,1,0,1,0,2,0,2,0,3,0,4,0,4,0,5,0,6,0,7,0,8,0,9,0,15,0,20,0,20],mb1
    LOOKUP t,[0,0,0,0,0,8,0,4,0,3,0,3,0,5,0,6,0,0,0,4,0,8,0,2,0,6,0,0,0,5,0,0,0,5,0,0,0,6,0,2,0,8,0,4,0,0,0,6,0,5,0,3,0,3,0,4,0,8,0,0,0,0,0,0],mb2
    	if t<32 then kiirmap
    	if t>32	then kiirman
    kiirman:	lcdout $fe,$c0:pause 100:lcdout " Magas: ","-",#mb1,",",#mb2,"dB":pause 250:TMR0=0:d1=0:INTCON=%10100000:goto main
    kiirmap:	lcdout $fe,$c0:pause 100:lcdout " Magas: "," ",#mb1,",",#mb2,"dB":pause 250:TMR0=0:d1=0:INTCON=%10100000:goto main
    '********************* A bemenetvalaszto rutinjai ********************
    bemnov:	if b<3 then b=b+1
    	goto new1
    bemcsokk:	if b>0 then b=b-1
    	goto new1
    new1:	low portd.7:low portd.6:low portd.5:low portd.4 : high portd.0[ bem + 4 ] : goto kirrhe
    '********************** 5 masodperces delay rutin  *******************
    'moved to near start of program
    Jun 2007
    Thank you very much
    But the "I2CWRITE" still don't work, the potentiometer value not change.
    Thank you very much
    Is this the first time you've tried using this particular IC?
    I've said it before, I'll say it again, start simple, work your way up...
    How do you really know that the value is supposed to change? How do you really know that your interrupts are being handled the way you want them to be handled?
    Replace the I2CWRITE commands with writes to the LCD, make sure you're logic is working, don't worry about what the chip does, just watch your numbers, see what they do first. Rewrite your program to write various values to the chip and the LCD and make sure the chip follows what you really want to do. Then integrate everything together. For all you know, there's something fundamentally wrong with the way you wrote the program.
    Try this out. If it works, it's up to you to figure out what's different...
    (and your English is fine, not perfect, but fine...and certainly a lot better than my ___________(<-insert language here).)
    DEFINE I2C_HOLD 1
    Define LCD_RSBIT 3
    Define LCD_EBIT 2
    buttontemp var byte : h var byte : b var byte : c var byte : t var byte : m1 var byte : m2 var byte : m3 var byte : m4 var byte : mb1 var byte : mb2 var byte
    mt1 var byte : mt2 var byte : d1 var byte : i2cdev var byte : sda var portc.4 : scl var portc.3 : goto skip_on_int
    delay_5s: d1=d1+1 : INTCON.2=0
    d1=0 : INTCON=0 : goto kiirhe 'hangero kiirasa
    resume
    enable
    skip_on_int:
    m1=0 : m2=$40 : m3=$80 : m4=$c0 : trisc=$e7 : trisd=$f : trisa=0 : trisb=0 : i2cdev=$50 : h=0 : b=0 : c=31 : t=31 : porta=63 : high portd.4 : adcon0=0
    adcon1=7 : cmcon=7 : sspcon=0 : pause 500 : lcdout $fe,1," Udvozollek" : pause 200 : i2cwrite sda,scl,i2cdev,[$1f,$5f,$9f,$df] : pause 100 : option_reg=7
    intcon=$a0
    main: button PORTC.1,0,0,0,buttontemp,1,novelhe : button PORTC.6,0,0,0,buttontemp,1,csokkenthe : button PortC.5,0,0,0,buttontemp,1,bemnov
    button PORTd.3,0,0,0,buttontemp,1,bemcsokk : button PORTC.0,0,0,0,buttontemp,1,bassn : button PORTD.1,0,0,0,buttontemp,1,basscs
    button PORTc.7,0,0,0,buttontemp,1,tren : button PORTd.2,0,0,0,buttontemp,1,trecs : Goto main
    Goto kiirhe
    Goto kiirhe
    mb1=c & m1 : mb2=c & m4 : i2cwrite sda,scl,,i2cdev,[mb1,mb2] : pause 200 : goto kiirmely
    mb1=c & m1 : mb2=c & m4 : i2cwrite sda,scl,i2cdev,[mb1,mb2] : pause 200 : goto kiirmely
    mt1=t & m2 : mt2=t & m3 : i2cwrite sda,scl,i2cdev,[mt1,mt2] : Pause 200 : goto kiirmely
    kiirhe: lcdout $fe,1," Hangero: ",#h : pause 250 : b=b+1 : lcdout $fe,$c0," Bemenet: ",#b : pause 250 : b=b-1 : goto main
    kiirmely: mb1=0 : mb2=0
    LOOKUP c,[0,20,0,15,0,9,0,8,0,7,0,6,0,5,0,4,0,4,0,3,0,2,0,2, 0,1,0,1,0,0,0,0,0,0,0,1,0,1,0,2,0,2,0,3,0,4,0,4,0, 5,0,6,0,7,0,8,0,9,0,15,0,20,0,20],mb1
    LOOKUP c,[0,0,0,0,0,8,0,4,0,3,0,3,0,5,0,6,0,0,0,4,0,8,0,2,0, 6,0,0,0,5,0,0,0,5,0,0,0,6,0,2,0,8,0,4,0,0,0,6,0,5, 0,3,0,3,0,4,0,8,0,0,0,0,0,0],mb2
    kiirmen: lcdout $fe,1," Mely: ","-",#mb1,",",#mb2,"dB":goto kiirmag
    kiirmep: lcdout $fe,1," Mely: "," ",#mb1,",",#mb2,"dB":goto kiirmag
    kiirmag: pause 250 : mb1=0 : mb2=0
    LOOKUP t,[0,20,0,15,0,9,0,8,0,7,0,6,0,5,0,4,0,4,0,3,0,2,0,2, 0,1,0,1,0,0,0,0,0,0,0,1,0,1,0,2,0,2,0,3,0,4,0,4,0, 5,0,6,0,7,0,8,0,9,0,15,0,20,0,20],mb1
    LOOKUP t,[0,0,0,0,0,8,0,4,0,3,0,3,0,5,0,6,0,0,0,4,0,8,0,2,0, 6,0,0,0,5,0,0,0,5,0,0,0,6,0,2,0,8,0,4,0,0,0,6,0,5, 0,3,0,3,0,4,0,8,0,0,0,0,0,0],mb2
    kiirman: lcdout $fe,$c0," Magas: ","-",#mb1,",",#mb2,"dB" : pause 250 : TMR0=0 : d1=0 : INTCON=%10100000 : goto main
    kiirmap: lcdout $fe,$c0," Magas: "," ",#mb1,",",#mb2,"dB" : pause 250 : TMR0=0 : d1=0 : INTCON=%10100000 : goto main
    goto new1
    goto new1
    new1: low portd.7 : low portd.6 : low portd.5 : low portd.4 : high portd.0[bem+4] : goto kirrhe
    Jun 2007
    Default Thanks
    Thanks for the post
    Unfortunately that way nor functionate. Already I've tried with one other DS1844 also , but nothing change. Already everything run-through on several occasions , but nothing make mistake not I had found.
  1. I2C Master/Slave 16F88/16F767 working code
    Last Post: - 23rd October 2012, 23:31
  2. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  3. Another I2C Slave Routine Problem
    By DanPBP in forum mel PIC BASIC Pro
    Last Post: - 19th February 2009, 06:50
  4. I2C Master Slave issues.
    Last Post: - 29th March 2008, 20:33
  5. Problem with I2C (24c32 eeprom)
    By lab310 in forum mel PIC BASIC Pro
    Last Post: - 5th February 2008, 10:00
