3 phase sequencing
Results 1 to 15 of 15
    Dec 2005
    Dave, as you pointed out I have directly input the phases thru' resistors. This effectively gives me only 3 half cycles per 3-phase cycle. For what you suggest would I need to have full-wave rectified signals (6 half cycles) at the inputs?
    Anand, assuming you use pins capable of Interrupt on Change, you'll get an interrupt on both the rising and falling edge. It's the same as using it for ZC detection in AN236 which also discusses the slight assymetry because of different trigger voltages for rising vs. falling edges.
    Look at the second oscilloscope screenshot on this page. It's a ZC detector on pin 13 of the PIC.The protection diodes on the pin effectively give you a square wave. In your case, the higher voltage will give steeper edges. You'll get 100 interrupts per second per phase or 300 total per second.
    Interrupt on Change cannot be preset for falling or rising edges. It interrupts on both and sets register bits to indicate the pin and rising or falling. On each interrupt you reset the timer, check the register bits to determine pin & polarity, clear the interrupt and output your coded representation of the event.
    P.S. What I'm suggesting is much, much simpler than what Skimask suggested.
    Anand, you'll get an interrupt on both the rising and falling edge.
    Great, Dave! Thats exactly what I needed to be on the right track.
    Thanks again.
    Anand
    Sep 2005
    Campbell, CA
    I have done exactly what you describe.
    I used 3 opto-isolators. Each opto had a diode in series and another diode across the LEDs so that they can't possibly get reverse-biased.
    I used a 15K 1W resistor in series for current limiting. It "looks" only at the positive half-cycles. The output of the phototransistor is close to a square wave, and is - of course, totally isolated. It works fine at both 110V and 230V.
    I can give you more details if you are interested in pursuing this approach.
    Charles Linquist
    Charles, I am *extremely* interested in knowing more about your technique.
    The hardware side is somewhat different from yours, but I too end up with a 'somewhat' square wave (half cycles only) at the pic input. And since I am not interested in the absolute values, I guess that difference can stay.
    I would however love to know more about the software approach you used.
    Thanks and regards,
    Anand
    Sep 2005
    Campbell, CA
    This code wasn't interrupt-driven, because it didn't need to be
    By changing "PhaseDelay" you can make it work for either 60 or
    400 hz, or by using PULSIN, you can make it auto-sensing.
    CheckACPhase:
    HighTimer = 0
    CheckPhaseA:
    IF PhaseA = 0 THEN ' Voltage is present or else wouln't be low
    WHILE PHASEA = 0:WEND
    HighTimer = 0
    GOTO CheckPhaseB
    Pauseus PhaseDelay
    HighTimer = HighTimer + 1
    IF HighTimer => 10 THEN GOTO PhaseAError
    GOTO CheckPhaseA
    PhaseAError: ; No phase A - was never low in 930 uSec period
    StatINfo.0 = 0 ; Can't check for proper phasing, so give error
    HighTimer = 0
    CheckPhaseB:
    If PhaseB = 0 THEN
    StatInfo.3 = 0 'Erase the error
    HighTimer = 0
    Goto CheckPhaseC
    WaitForLowB:
    Pauseus PhaseDelay
    IF PhaseB = 0 THEN goto PhaseBError2
    IF HighTimer => 10 THEN GOTO PhaseBError1
    GOTO WaitForLowB
    PhaseBError1: ; No signal
    StatINfo.1 = 0 ; Can't check for proper phasing, so give error
    HighTimer = 0
    GOTO CheckPhaseC
    PhaseBError2: ; Signal, but wrong phase
    HighTimer = 0
    CheckPhaseC:
    If PhaseC = 0 THEN
    Goto DunPhaseCheck
    Pauseus PhaseDelay
    IF HighTimer => 10 THEN GOTO PhaseCError
    GOTO CheckPhaseC
    PhaseCError:
    StatInfo.2 = 0
    DunPhaseCheck:
    IF Statinfo.0 = 0 or StatInfo.1 = 0 OR Statinfo.2 = 0 Then
    StatInfo.3 = 1
    ; When returned, Statinfo bit 3 = 0 = OUT OF PHASE
    ; bit 0 = 0 = PhaseA not present
    ; bit 1 = 0 = PhaseB not present
    ; bit 2 = 0 = PhaseC not present
    ; When any phase is not present, bit 3 is always SET.
    Charles Linquist
    Wow, Charles, the whole thing on a platter!
    Thank you so much. Appreciate your sharing the code.
    Anand
  1. 3 phase supply detector challenge
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 15th May 2009, 08:54
  2. 3 phase PWM with dsPIC30F2020
    By nemmard in forum mel PIC BASIC
    Last Post: - 21st January 2009, 15:19
  3. Understanding 3 phase sequencing
    By ardhuru in forum General
    Last Post: - 22nd June 2008, 11:14
  4. Someone help me to simplify this
    By thrix in forum General
    Last Post: - 21st February 2004, 06:01
  5. Help wanted..
    By thrix in forum mel PIC BASIC Pro
    Last Post: - 18th February 2004, 00:44
