PIC 18F4550, firmware
Results 1 to 14 of 14
    May 2007
    I guess, firmware needs first 2kb of the memory.Therefore the first 800h bits must be allocated...
    PIC18F4550
    PICDEM FS USB DEMO TOOL VERSION 1.00
    Quote Originally Posted by kutsi View Post
    PIC18F4550
    As long as your bootloader is supported by PBP, then you shouldn't have to worry about anything.
    What about the rest of the questions?
    May 2007
    Define ONINT_USED 1
    LED var PORTL.0 ' Alias PORTB.0 to LED
    loop: High LED ' Turn on LED connected to PORTL.0
    Pause 500 ' Delay for .5 seconds
    Low LED ' Turn off LED connected to PORTL.0
    Goto loop
    This is a simple example from the guide.
    Do I need to define anythin further? osc 20mhz?
    PBP 2.46
    Define ONINT_USED 1
    Goto loop
    PBP 2.46
    Which page is 'Define ONINT_USED 1' on in the guide?
    And since when does a PIC18F4550 have a PortL?
    May 2007
    PORTL.0 is a user defined variable for PORTB.0
    PAGE 6
    PAGE 6
    It is? That's a good trick! How about this...
    PortL encompasses pins 0 - 7 (PortB for a 40 pin PIC), and PortH encompasses pins 8-15 (PortC for 40 pin PIC).
    At least they do according to pg.26 and 27 (section 4.11).
    Now then, how about the rest of the questions...again...
    May 2007
    PBP 2.46
    mplab ICD 2 as programmer
    mplab IDE 7.5
    anything missing?
  1. Pic to Pic Firmware upgrade
    By rjones2102 in forum mel PIC BASIC Pro
    Last Post: - 13th October 2007, 01:06
  2. getting started with a PIC 18F4550
    By bigbear in forum General
    Last Post: - 16th October 2006, 03:31
  3. Build PIC bootloader firmware in PBP?
    By Joe Rocci in forum mel PIC BASIC Pro
    Last Post: - 18th August 2006, 20:53
  4. Pic 18F4550 & VB6
    By lentz in forum USB
    Last Post: - 5th April 2006, 01:55
