Using LCD from Mechatronics Demo Board
Results 1 to 16 of 16
    Quote Originally Posted by Michlis View Post
    I have a Microchip's Mechatronics Demo Board and I am trying to use on board LCD with PBP. In the PBP manual it says that: "If a 4-bit bus is used the top 4 LCD data bits must be connected to either the bottom 4 or top 4 bits of one port."
    Now the problem is that LCD is already pre-connected to the PIC and as it says in the data sheet fist 4 ports are COM0-COM3. So I took the board and it looks that COM0 is on pin RB4, COM1 is RB5, COM2 RA2, COM3 RD0. Is it possible to run this LCD in PBP with such connections? How should I set DEFINEs?
    It's possible to run that LCD with a PIC, just not with the LCDOUT commands.
    The LCDOUT commands used in PBP with the PICs are for LCDs with built-in Hitachi 44780 style controllers with a parallel interface.
    Judging from the connector, what you've got is probably a 'dumb' LCD. You'll most likely have to dig up the spec's for the LCD, write a program to handle the multiplexing, etc.etc.etc.
    If you want an LCD, it's a heck of a lot easier to get on eBay or wherever and just buy a 16x2 LCD from somewhere for $10.
    Apr 2007
    Copenhagen
    I have found the datasheet here:
    http://www.varitronix.com/Product/LC...332-DP(R0).pdf
    but I don't understand the table at the end of it. I guess it's the most important part.
    Ok, now I know that, but unfortunately I have to stick to this LCD.
    How should I write a PBP code to handle this LCD, what do I need to take care of, in which order?
    I'd be grateful for any hints.
    Basically, that table says that if you put power (whatever that power may be according to the datasheet) on pin #5 and a ground on COM1, then the 'RC' will show on the LCD.
    PBP will NOT drive this LCD thru it's built in commands. As I said before, this is a 'dumb' LCD.
    You're going to need 14 pins from a PIC to provide power to a segment, and 4 MOSFETs/transistors to apply a ground to a COMmon.
    Then you're going to have to write software to drive the LCD, multiplexing various signals to get it to display what you want to display. Then you're going to have to get it to do this roughly 20+ times per second so your eyes don't see any flickering.
    You HAVE to stick with this LCD... This LCD is going to 'cost' at least 18 pins from a PIC and a LOAD of code and headaches... I'd talk to whoever is making you do this...and slap them up a bit...
    But if you must, do some searching here, there's a few projects around here that deal with multiplexing a display,etc.
    Apr 2007
    Copenhagen
    Ok, that sounds quite tricky
    PIC16F917 has some LCD module. Maybe it's possible to use it, so that it will be easier and simpler to drive this 'dumb' LCD? What kind of functionality does this LCD module provide?
    Mentor, Ohio
    Smile
    Hi Michlis,
    The LCD on your demo board is similar to driving a 7 segment display. Your program will need to output the data to the first display digit, then to the second, then to the third, etc. There are many types of LCD displays out there. The ones that are used with PBP are quite different from the one on your demo board. The PBP LCDOUT routines will not work with the type of LCD display that you have. I just took aglance at microchip's website and there seems to be alot of reading material in relation to their LCD PICs. The 16F917 is a specialty chip with a built in LCD driver so you need to learn how to address that driver to get information displayed. The built-in driver probably explains why the chip has a large program memory, 14K!
    Didn't your demo board come with sample applications? If so, why don't you use the information there to create an assembly routine to operate the display within a PBP program.
    I personally use the regular LCD displays in either a serial or parallel manner whereby I can use LCDOUT or Serout2 commands to display data quick and simple!
    HTH,
    BobK
    Apr 2007
    Copenhagen
    After all, the LCD works. Here is the code that I use to display "1234":
    PAUSE 1000 'wait for LCD start up
    LCDPS = %00110001 'Selecting the frame prescale
    LCDSE0.0 = 1 'Segment pins
    LCDSE0.1 = 1
    LCDSE0.2 = 1
    LCDSE0.3 = 1
    LCDSE0.6 = 1
    LCDSE1.3 = 1
    LCDSE2.0 = 1
    LCDSE2.5 = 1
    LCDSE2.6 = 1
    LCDSE2.7 = 1
    LCDCON = %01000011 'Multiplex,bias,timing, sleep
    LCDDATA0 = %01001000 'initial LCD values "1234"
    LCDDATA1 = %00001000
    LCDDATA2 = %10100000
    LCDDATA3 = %00000000
    LCDDATA4 = %00001000
    LCDDATA5 = %11100000
    LCDDATA6 = %00001100
    LCDDATA7 = %00000000
    LCDDATA8 = %10100000
    LCDDATA9 = %01001000
    LCDDATA10 = %00000000
    LCDDATA11 = %00000000
    PIR2.4 = 0 'clearing LCD interrupt flag
    LCDCON = %01010011 'enabling bias voltage pins
    LCDCON = %11010011 'enabling the LCD module
    however, I have problems when trying to run PWM module while using LCD. I will post about it soon.
    Apr 2007
    Copenhagen
    As mentioned above, I have problems when trying to use LCD (code above) and HPWM at the same time.
    This is my HPWM program:
    'Connections:
    'SW2->RD1 increase switch
    'SW3->RA4 decrease switch
    'P1->Vdd motor turned on constantly
    'RC5/CCP1->N2 CCP1 is pwm output pin
    'DC motor is connected to DRIVE 1 and DRIVE 2
    'HPWM initialization
    duty VAR WORD ' Duty cycle value )
    TRISC.5 = 0 ' Set PORTC.5 (CCP1) to output
    CCP1CON = %00001100 ' Set CCP1 to PWM
    T2CON = %00000101 ' Turn on Timer2, Prescale=4
    PR2 = 249 ' Set PR2 to get 1KHz out
    duty = 500 ' Set duty cycle to 50%
    up var PORTD.1 'user-friendly names for ports
    down var PORTA.4
    'Main program loop
    loop:
    CCP1CON.4 = duty.0 ' Store duty to registers as
    CCP1CON.5 = duty.1 ' a 10-bit word
    CCPR1L = DUTY >> 2
    'check if button "up" is pressed and duty is not maximum
    IF (up=0) AND (duty<1000) THEN
    duty=duty+50
    PAUSE 200
    'similar as before but for reducing the speed
    IF (down=0) AND (duty>0) THEN
    duty=duty-50
    PAUSE 200
    GoTo loop ' Do it forever
    When I combine these two programs (first LCD then HPWM) it starts to work that is I get "1234" on the LCD and then motor starts to turn but only for 2-3sec. Later is just stops. It looks like PWM signal just dies...?!
    I have no idea why these two modules (LCD and HPWM) cannot work togather? I have checked the pins and timing sources but don't see any possible conflicts?
  1. 16f688 LCD what have I done wrong
    Last Post: - 8th August 2009, 20:54
    Last Post: - 7th December 2008, 15:17
  3. Need help with LCD number display.
  4. LCD will not start
  5. Replies: 8
    Last Post: - 7th December 2006, 16:42
