Using LCD from Mechatronics Demo Board
Results 1 to 16 of 16
    Apr 2007
    Copenhagen
    As mentioned above, I have problems when trying to use LCD (code above) and HPWM at the same time.
    This is my HPWM program:
    'Connections:
    'SW2->RD1 increase switch
    'SW3->RA4 decrease switch
    'P1->Vdd motor turned on constantly
    'RC5/CCP1->N2 CCP1 is pwm output pin
    'DC motor is connected to DRIVE 1 and DRIVE 2
    'HPWM initialization
    duty VAR WORD ' Duty cycle value )
    TRISC.5 = 0 ' Set PORTC.5 (CCP1) to output
    CCP1CON = %00001100 ' Set CCP1 to PWM
    T2CON = %00000101 ' Turn on Timer2, Prescale=4
    PR2 = 249 ' Set PR2 to get 1KHz out
    duty = 500 ' Set duty cycle to 50%
    up var PORTD.1 'user-friendly names for ports
    down var PORTA.4
    'Main program loop
    loop:
    CCP1CON.4 = duty.0 ' Store duty to registers as
    CCP1CON.5 = duty.1 ' a 10-bit word
    CCPR1L = DUTY >> 2
    'check if button "up" is pressed and duty is not maximum
    IF (up=0) AND (duty<1000) THEN
    duty=duty+50
    PAUSE 200
    'similar as before but for reducing the speed
    IF (down=0) AND (duty>0) THEN
    duty=duty-50
    PAUSE 200
    GoTo loop ' Do it forever
    When I combine these two programs (first LCD then HPWM) it starts to work that is I get "1234" on the LCD and then motor starts to turn but only for 2-3sec. Later is just stops. It looks like PWM signal just dies...?!
    I have no idea why these two modules (LCD and HPWM) cannot work togather? I have checked the pins and timing sources but don't see any possible conflicts?
    Quote Originally Posted by Michlis View Post
    duty=duty-50 : PAUSE 200
    If duty is 10 and you subtract 50 from it, you'll end up with a negative number, which PBP doesn't handle. I think you want the lines to be:
    IF (down = 0) AND (duty => 50) THEN blah blah blah...
    Nah, PBP handle it. if 0-50 in a byte variable will return 205 or 206.
    But 'duty' is a word and, if it does end up being a 'negative number', it'll be above the 1000 limit set in the IF/THEN above and nothing will happen to 'duty' and the program will appear to go stupid.
    Talking
    <table><td></td><td>hum hum... pfff i knew... it was a test to know if you follow... HUM HUM</td><td></td></table>
    Do I get anything as a prize?
    Wink
    My respect for few days... or some of those...
    Apr 2007
    Copenhagen
    Smile Conclusions
    You are of course right, but I start the program with duty=500 and use only +/-50 steps, so this IF statement is correct in my case.
    After some time I found the bug. At first I set all LCDSEn registers and it was a mistake since the LCD uses only few pins, so my button input pins were in segment functionality instead of I/O. Now I only set the segment pins that are actually used by LCD.
  1. 16f688 LCD what have I done wrong
    Last Post: - 8th August 2009, 20:54
    Last Post: - 7th December 2008, 15:17
  3. Need help with LCD number display.
  4. LCD will not start
  5. Replies: 8
    Last Post: - 7th December 2006, 16:42
