PIC16F877A - Timer0 won't interrupt
Results 1 to 20 of 20
    Feb 2005
    Kolkata-India
    Default Typo or I missed that instruction
    [code]
    incf _ledcnt ;increment the counter
    Skimask I think it should be incf and is a simple typo.
    Sougata
    Quote Originally Posted by sougata View Post
    Yep, should be, and is......then again, it is Friday the 13th....maybe my keyboard is playing em no skcirt
    Interrupts and the MSC Debugger don't get along very well together.
    You must DISABLE debugging in any interrupt routines.
    DISABLE DEBUG
    asm
    tmroverflow movwf	wsave
                retfie
    ENABLE DEBUG
    For an 877, you should use $70 for the wsave address.
    OPTION_REG = %00000101 sets the prescaler to 1:64. (comment says 32)
    and, like skimask said ... set the LED's pin to output.
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Also a working example on MELABs website
    http://www.melabs.com/resources/samples/pbp/asmint.bas
    (maybe you got your start for yours there? I did not check if they are similar)
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Apr 2007
    Delft, the Netherlands
    Thanks all for your responds, will try them out on monday, it's weekend now. But thank you all very very much !!!
    Apr 2007
    It's working perfectly!!! Thanks for the help!
    Cheers,
    William
    Apr 2007
    Hello all!!
    An update and help request on my program:
    define loader_used 1
    define osc 20
    ;---Defining Variables---
    wsave var   byte $70 system
    ssave var   byte bank0 system
    psave var   byte bank0 system
    count0  var byte bank0 system
    count1  var byte bank0 system
    count2  var byte bank0 system
    count3  var byte bank0 system
    count4  var byte bank0 system
    count5  var byte bank0 system
    hulp0   var byte bank0 system
    hulp1   var byte bank0 system
    hulp2   var byte bank0 system
    whulp   var byte bank0 system
    pclhulp var byte bank0 system
    sthulp  var byte bank0 system
    ;---Zeroing registers---
    count0   = 0
    count1   = 0
    count2   = 0
    count3   = 0
    count4   = 0
    count5   = 0
    hulp0    = 0
    hulp1    = 0
    hulp2    = 0
    whulp    = 0
    pclhulp  = 0
    sthulp   = 0
    STATUS.0 = 0
    Goto main ;Skip interrupt routine
    define INTHAND int
    DISABLE DEBUG
    asm
    ;---Save W, STATUS and PCLATH---
    int movwf whulp
        swapf STATUS, W
        clrf STATUS
        movwf sthulp
        movf  PCLATH, W
        movwf pclhulp
    ;---Clock program---
        incf count0, F
        movwf count0
        call check
        movf count0, W
        btfss STATUS,0
        goto eindafwerking
        incf count1, F
        movwf count1
        call check
        movf count1, W
        btfss STATUS,0
        goto eindafwerking
        incf count2, F
        movwf count2
        call check
        movf count2, W
        btfss STATUS,0
        goto eindafwerking
        incf count3, F
        movwf count3
        call check
        movf count3, W
        btfss STATUS,0
        goto eindafwerking
        incf count4, F
        movwf count4
        call check
        movf count4, W
        btfss STATUS,0
        goto eindafwerking
        incf count5, F
        movwf count5
        call check
        movf count5, W
        btfss STATUS,0
        goto eindafwerking
    ;---Restore W, STATUS and PCLATH---
    eindafwerking movf pclhulp, W
                  movwf PCLATH
                  swapf sthulp, W
                  movwf STATUS
                  swapf whulp, F
                  swapf whulp, W
                  bcf intcon,2
                  retfie
    ;---Check function for counts to be 99h maximum (NOT USED YET)---
    check return
    ENABLE DEBUG
       INTCON = %10100000                  ;GIE enabled, T0IE enabled
       OPTION_REG = %00000111
       goto loop
    loop:   goto loop                           ;Wait here for interrupt
    The program before (with the LED) was to time it on 1 millisecond, the final program (which isn't this one ofcourse ) is for measurement purposes.
    Test step 2:
    What I try to do here is to make a counter, that increments count0 when the timer overflows, then when count0 is full, it increments count1 etc etc. Atleast... it should do that....
    The things i tried to make it work:
    - Reset the C flag of STATUS, only this made only count0 to run.
    - Switched , W with , F and vice versa (example: STATUS, W becomes STATUS, F)
    A colleague told me to make some own save location (pclhulp, whulp and sthulp). I'm not sure if this is okay...
    If someone could help me out again, I will be very gratefull (again!!).
    Cheers,
    William
    (Excuse me for the dutch labeling, it shouldn't be be much of a problem i guess )
    /EDIT:
    Allrightey I fixed the problem myself! Yay ^^!
    define osc 20
    count0   = 0
    count1   = 0
    count2   = 0
    count3   = 0
    count4   = 0
    count5   = 0
    hulp0    = 0
    hulp1    = 0
    hulp2    = 0
    whulp    = 0
    pclhulp  = 0
    sthulp   = 0
    STATUS.2 = 0
    define INTHAND int
    DISABLE DEBUG
    asm
    int movwf whulp
        swapf STATUS, W
        clrf STATUS
        movwf sthulp
        movf  PCLATH, W
        movwf pclhulp
        incf count0, F
        movf count0, W
        call check
        movwf count0
        btfss STATUS,2
        goto eindafwerking
        bcf STATUS,2
        incf count1, F
        movf count1, W
        call check
        movwf count1
        btfss STATUS,2
        goto eindafwerking
        bcf STATUS,2
        incf count2, F
        movf count2, W
        call check
        movwf count2
        btfss STATUS,2
        goto eindafwerking
        bcf STATUS,2
        incf count3, F
        movf count3, W
        call check
        movwf count3
        btfss STATUS,2
        goto eindafwerking
        bcf STATUS,2
        incf count4, F
        movf count4, W
        call check
        movwf count4
        btfss STATUS,2
        goto eindafwerking
        bcf STATUS,2
        incf count5, F
        movf count5, W
        call check
        movwf count5
        bcf STATUS,2
        goto eindafwerking
                  movwf PCLATH
                  swapf sthulp, W
                  movwf STATUS
                  swapf whulp, F
                  swapf whulp, W
                  bcf intcon,2
                  retfie
    check return
    ENABLE DEBUG
       goto loop
    What I did wrong:
    - I switched the movf and the movwf instructions!
    - Checked the wrong bit, it checked the carry flag (Status.0) instead of the Zero flag (Status.2)
    I feel so noobish >)
    Last edited by WishMaster^; - 17th April 2007 at 10:27. Reason: Made some things more clear.. EDIT2: Fixed the problem..
  1. Can't ID interrupt source with this IntHandler??
    Last Post: - 3rd June 2009, 02:35
  2. Sleep Mode
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 13th March 2008, 10:31
  3. Ping Darrel Taylor - Timer0 Instant Interrupt
    By JEC in forum mel PIC BASIC Pro
    Last Post: - 9th January 2007, 11:20
  4. USART interrupt in PIC16F877A
    By amindzo in forum General
    Last Post: - 26th August 2006, 18:51
    Last Post: - 6th March 2005, 01:07
