I can't even make an LED flash!
Results 1 to 13 of 13
    New Zealand
    Got it figured! For some reason the thing won't run at under 4.2V I've been trying to run it at 3.0V - I might revert to the 628A as it's better at lower power - on saying that the datasheet for the 628 does say it will run at 3.0V Thanks for your time everyone, I should have bumped the voltage to 5 much earlier. Good suggestion too skimask about the prototype boards I've had trouble with mine in the past but for some reason i still trust them - figure that one out!
    Quote Originally Posted by George View Post
    Well, the graph in the 16F628 datasheet does show that at 4mhz the minimum required voltage is 4.5v, even though the line goes up from 3.0 to 4.5v at that exact point.
    So you have to wonder. Is it 4.5v @ 4mhz or 3.0v @ 4mhz minimum? Must be 4.5v...
    And the datasheet also states that the minimum supply voltage is 3v, no matter the speed.
    Maybe it'll run at 3.999999 mhz at 4.2v... after all, that's what the graph says!
    Live and learn...
    Happy PIC'ing...finally...
    New Zealand
    Thanks for that - I didn't even think to look at the electrical specs I just noted the voltage range on the intro page (didn't help that most of the time I was looking at the 628A datasheet either)
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. LCD will not start
  3. elapsed time between two led flash...
    By dario in forum mel PIC BASIC Pro
    Last Post: - 5th February 2006, 17:09
  4. switches & LEDs ... my first attempt
    By yankee in forum mel PIC BASIC Pro
    Last Post: - 28th January 2006, 13:51
  5. can't even flash an LED
    By bruno333 in forum mel PIC BASIC Pro
    Last Post: - 28th April 2005, 14:27
