PIC to serial with visual basic
Results 1 to 8 of 8
    Feb 2005
    Kolkata-India
    Default Hardware Tx/Rx RTFM
    Here is a portion from the PBP manual
    Since the serial reception is done in hardware, it is not possible to set
    the levels to an inverted state to eliminate an RS-232 driver.
    Therefore
    a suitable driver should be used with HSERIN.
    Any idea what this means ? I don't know or may be I do
    Using the hardware pins with a software serial (inverted) works but makes no sense as anyway you don't use the hardware peripheral. So time to spend on MAX or be happy with soft serial.
    Sougata
    Quote Originally Posted by sougata View Post
    Sure ya do. HSERIN/OUT uses the UART, which is monitored by PBP for input/output. So you need the correct RS232 voltages...
  1. Serial VB 2005 pic 16f877a problems
    By Snap in forum mel PIC BASIC Pro
    Last Post: - 8th July 2013, 01:52
  2. serial to PIC
    By kindows in forum mel PIC BASIC Pro
    Last Post: - 14th July 2009, 14:58
  3. Replies: 11
    Last Post: - 12th July 2008, 03:36
  4. vb6 to pic basic
    By Darrenmac in forum mel PIC BASIC Pro
    Last Post: - 19th December 2005, 02:56
  5. Serial communication PIC to PIC help.
    Last Post: - 24th January 2005, 16:45
