PIC to serial with visual basic
Results 1 to 8 of 8
    Jul 2006
    Default PIC to serial with visual basic
    Hello,
    I am trying to hook up my PIC18F4550 to my serial port and send data using Visual Basic. The code for the PIC is below. I have a 22K resistor on the RX line of the PIC. The RTS and CTS lines I have working (thanks to skimask) but I can't seem to get the RX to work. The PC should transmit a "4" and the PIC should receive it and test its value. For visual basic the instruction I am using is: SerialPort.Write("4"). I believe I have the right baud and everything setup (9600) but I can't be sure (the rest is the default setup). Any help is appreciated! Thanks,
    -Mike
    Code on PIC:
    Include "modedefs.bas"
    define HSER_CLROERR 1
    define HSER_RCSTA 90h
    define HSER_BAUD 9600
    define HSER_TXSTA 20h
    define OSC 4
    rts var porta.2
    cts var portd.3
    led var portd.2
    rx var portc.7
    OK var word
    input rts
    output cts
    output led
    ADCON1 = %00001111
    low led : low cts
    while rts = 1
    high cts
    SERIN rx,N9600,OK
    if ok = "4" then
    high led
    wend
    low cts
    Quote Originally Posted by mbw123 View Post
    Code on PIC:
    define HSER_CLROERR 1 : define HSER_RCSTA 90h : define HSER_BAUD 9600
    define HSER_TXSTA 20h : define OSC 4 : rts var porta.2:cts var portd.3
    led var portd.2 : rx var portc.7 : OK var word : input rts : output cts
    output led : ADCON1=15 : low led : low cts
    while rts = 1
    high cts : SERIN rx,N9600,OK
    if ok = "4" then
    high led
    wend
    low cts
    Why are you using the RTS & CTS lines? Just curious...I've never used them, never had a need, kinda complicates thing unneccesarily. Try this whole thing without the RTS and CTS lines. Set Windows to 'Handshaking-None' in the serial properties. See what happens then. Again, you're breaking it down, starting super-simple, then working your way up.
    Another thing, you're using SERIN with HSER defines. Why?
    And SERIN @ 4mhz isn't exactly reliable. Switch down to 2400 and see what happens.
    You're also not using a MAX232. It should work with a PC using the inverted serial modes, but the voltage levels might not be high enough. You might end up using one. It's always worked for me, but you never know.
    Incidentally, I got over 100 threads here on this site alone all about serial interfacing, PC's, visual basic, hyperterminal, etc.
    Jul 2006
    OK, thanks for the response.
    I tried it without the RTS / CTS lines but it still didn't work.
    Sorry about the HSER defines, I used them before and I forgot to get rid of them. Even without them and switching the baud rates, though, it still doesn't work.
    "You're also not using a MAX232. It should work with a PC using the inverted serial modes, but the voltage levels might not be high enough. You might end up using one. It's always worked for me, but you never know."
    Yeah, I may end up with a MAX232. I just want to avoid it if at all possible.
    I really don't know where to go from here. Any help or suggestions?
    Thanks.
    -Mike
    Did you switch to 2400 baud?
    Did you read the manual where it says that 9600 baud might not be possible at 4mhz?
    Jul 2006
    Yeah, I switched it to 2400 baud rate and turned off the handshake. Maybe the visual basic code is wrong or the code on the PIC should be "if OK = 4" instead of 4 being in quotation marks. Or am I missing something that's staring me in the face?
    Thanks for the help.
    -Mike
    -Mike
    Try this. It echo's everything you type on hyperterminal, but echo the same character 3 times and toggle the led every time you hit a key, that way you know it's really working..
    rx var portc.7 : output rx : tx var portc.6 : input tx
    led var portd.2 : output led : serialdata var byte : ADCON1 = $F
    toggle led 'just show the program is running
    serin rx , N2400 , serialdata
    serout tx , n2400 , [ serialdata , serialdata , serialdata ]
    Once again, you break it down, make it super simple, then build it back up...
  1. Serial VB 2005 pic 16f877a problems
    By Snap in forum mel PIC BASIC Pro
    Last Post: - 8th July 2013, 00:52
  2. serial to PIC
    By kindows in forum mel PIC BASIC Pro
    Last Post: - 14th July 2009, 13:58
  3. Replies: 11
    Last Post: - 12th July 2008, 02:36
  4. vb6 to pic basic
    By Darrenmac in forum mel PIC BASIC Pro
    Last Post: - 19th December 2005, 01:56
  5. Serial communication PIC to PIC help.
    Last Post: - 24th January 2005, 15:45
