show on LCD decimal numbers
Results 1 to 9 of 9
    Jun 2006
    Default show on LCD decimal numbers
    It's possible to show on LCD decimal numbers;
    value = SQR 10 ' give 3,16
    i use this:
    Lcdout $fe,1, DEC (value DIG 2), "." ,DEC (value DIG 1) ,DEC (value DIG 0)
    but not show correct.
    Quote Originally Posted by savnik View Post
    i use this:
    Let me guess....you're expecting 3.16 right?
    Do a search in the PBP manual for floating point math and tell me what you come up with (hint: we've already been through this in January, see post #8 of the "16f877 with LM335 problem" thread ).
    Apr 2006
    New Hampshire USA
    Smile A similar question (with answer)
    Hi savnik,
    This is a very common problem.
    A similar question is asked here.
    Be sure to see Darrel's great explanation:
    http://www.picbasic.co.uk/forum/showthread.php?t=5545
    -Adam-
    Jun 2006
    Default math problem
    i have two variables:
    x var word
    y var word
    and x < y.
    How to show on lcd the result of x/y , or the value = SQR x/y
    This has worked for me. Play with it.
    RESULT	VAR	WORD
    LCDOUT $FE,1,DEC RESULT/100,".",DEC2 RESULT//100
    Note DEC2 and // after the dummy “.”
    The DEC2 gives the last two digits and // gives the remainder or MOD of a number.
    I use this to monitor battery voltage to the hundredths place.
    x var word
    y var word
    and x < y.
    Right...I understand that. I'm still trying to make you understand.
    Again, I ask you to do a search in the PBP manual for floating point math and tell me what you come up with (same hint: we've already been through this in January, see post #8 of the "16f877 with LM335 problem" thread ).
    Jun 2006
    I have read the manual for floating point very well and i have see post #8 of the "16f877 with LM335 problem" thread.
    i use this:
                                            ' forwardpower  = 400
                                            ' reflectedpower = 20
        B0 = forwardpower/reflectedpower    ' = 400/20 = 20
        B1 = 10000/B0                       ' = 10000*1/20 = 500
        B2 = SQR B1                         ' = 22,360679
        B3 = (10000+B2*100)/(100-B2)        ' = (10000+22*100)/(100-22) = 12200/78 = 156,4
        Lcdout $fe,$90, "SWR  : ",DEC (B3 DIG 2),".", DEC (B3 DIG 1),DEC (B3 DIG 0)
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
    Last Post: - 8th August 2009, 20:54
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  5. LCD will not start
