Logarithm in PBP
Results 1 to 25 of 25
    Jun 2006
    May I suppose the number in the "Power" column has to be displayed ... or is it just your Index ???
    In this case ... It would be much easier to use if the "Volts" were integers numbers and "Power" decimals ... I know: some more work for you !!!
    See Also Here : http://curveexpert.webhop.net/
    That Helps ... isn't it ???
    I display only the volts
    Question ???????????????????????????????????
    Quote Originally Posted by savnik View Post
    read from previous posts :
    << I want to measure the volts at the input of pic , and show on LCD the power >>
    Could you give me a decent explanation ???
    Jun 2006
    I have a linear for FM and i want to measure the power.
    From the power meter i take the indication which is in volt.This volt i want to show on LCD. But the power change in logarithm scale and this is my problem.
    Question What do you really want to do ???
    > Where's the problem, then, If you only want to display the voltage ???
    > This needs some USEFUL enlightments ... if you do not need to display the Power !!!
    > Do you want to display Voltage in dBv ???
    > Do you want to display Voltage in some BARGRAPH mode ??? ...
    those ONLY could give any sense to your question !!!
    Jun 2006
    My english is not so good.
    I want the voltage which measure with the pic , to show on lcd in dBm or dBv or watt (the table which post in #6)
    Loveland CO USA
    Smile voltage to power simple math
    Savnik,
    You need to get a book on basic electronics. Voltage Current Power and Resistance.
    Power = voltage * current
    In your case you can not see the current so: Power = Voltage * Voltage /Resistance (Voltage squared)
    To prove that look at your table. Voltage of 22.4 volts = 10 watts and Voltage of 44.7 volts = 40 watts. Voltage increases 2:1 and power increases 4:1. That proves there is a voltage squared * constant.
    Voltage * Voltage/50 = Power
    To convert to db is very hard or very simple depending on how you look at it. You can fight BIG math for weeks. When you understand db it is almost as simple as finding Power. I will not tell you how now. You need to think about it for a while.
    RonS.
    Jun 2006
    Quote Originally Posted by ronsimpson View Post
    Savnik,
    RonS.
    I am a electronic for 30 years.
    Thank you for your help. You give me some idea how to calculate.
    Apr 2006
    New Hampshire USA
    Smile
    Hi Savnik,
    If I read your problem correctly:
    From the power meter i take the indication which is in volt. This volt I want to show on LCD. But the power change in logarithm scale and this is my problem.
    You have a RF amplifier that has an analog power meter. The power meter reads a voltage and displays the power on a Logarithmic scale. The input, to move the meter, is voltage. The scale painted on the meter face is logarithmical.
    You need the PIC’s adc input to read the DC voltage running the meter and then using mathematics or a “look-up” table convert the voltage to the equivalent power in Watts. You have already calculated the table, posted in your previous post.
    Is this close to the question? I am just trying to help with clarifying the question. Sorry I don’t have an answer for you.
    -Adam-
    Jun 2006
    Quote Originally Posted by Pic_User View Post
    Hi Savnik,
    -Adam-
    Yes, it is my question.
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 12:55
  2. Extensions to PBP variables
    By John_Mac in forum mel PIC BASIC Pro
    Last Post: - 23rd October 2009, 05:21
  5. PBP / XP Crash
    By pondindustrial in forum mel PIC BASIC Pro
    Last Post: - 27th November 2005, 03:16
