Logarithm in PBP
Results 1 to 25 of 25
    Jun 2006
    Hi, Savnik
    Jerson is right ... the simplest Pic way is to build a retrieving table.
    IN PbP that's called LOOKDOWN2 ... ( catches the closest values, sup and inf ... just think to use a clever index !!! )
    Then just have to add a linear approx. between table values ...
    Buuuuuut, My old brain tells me it is very easy to do it with 3or4 couples of linearising resistors and diodes ...
    or to use a logarithmic AOP !!!
    Last and simplest solution: The App Notes of ICL 7106 or 7136 show a logarithmic scale design ...
    Which is closest to your requirements ??? ...
    I have make a table.
    I want to measure the volts at the input of pic , and show on LCD the power
    POWER	VOLT		POWER	VOLT
    1	7,1		26	36,1
    2	10,0		27	36,7
    3	12,2		28	37,4
    4	14,1		29	38,1
    5	15,8		30	38,7
    6	17,3		31	39,4
    7	18,7		32	40,0
    8	20,0		33	40,6
    9	21,2		34	41,6
    10	22,4		35	41,8
    11	23,5		36	42,4
    12	24,5		37	43,0
    13	25,5		38	43,6
    14	26,5		39	44,2
    15	27,4		40	44,7
    16	28,3		41	45,3
    17	29,2		42	45,8
    18	30,0		43	46,4
    19	30,8		44	46,9
    20	31,6		45	47,4
    21	32,4		46	48,0
    22	33,2		47	48,5
    23	33,9		48	49,0
    24	34,6		49	49,5
    25	35,4		50	50,0
    Question
    May I suppose the number in the "Power" column has to be displayed ... or is it just your Index ???
    In this case ... It would be much easier to use if the "Volts" were integers numbers and "Power" decimals ... I know: some more work for you !!!
    See Also Here : http://curveexpert.webhop.net/
    That Helps ... isn't it ???
    Quadratic Fit: y=a+bx+cx^2 ( y: Power ; x :Voltage )
    Coefficient Data:
    a = 0.00076569488
    b = -8.0880958e-005
    c = 0.019999816
    Jun 2006
    I display only the volts
    Question ???????????????????????????????????
    Quote Originally Posted by savnik View Post
    read from previous posts :
    << I want to measure the volts at the input of pic , and show on LCD the power >>
    Could you give me a decent explanation ???
    Jun 2006
    I have a linear for FM and i want to measure the power.
    From the power meter i take the indication which is in volt.This volt i want to show on LCD. But the power change in logarithm scale and this is my problem.
    Question What do you really want to do ???
    > Where's the problem, then, If you only want to display the voltage ???
    > This needs some USEFUL enlightments ... if you do not need to display the Power !!!
    > Do you want to display Voltage in dBv ???
    > Do you want to display Voltage in some BARGRAPH mode ??? ...
    those ONLY could give any sense to your question !!!
    Jun 2006
    My english is not so good.
    I want the voltage which measure with the pic , to show on lcd in dBm or dBv or watt (the table which post in #6)
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 13:55
  2. Extensions to PBP variables
    By John_Mac in forum mel PIC BASIC Pro
    Last Post: - 23rd October 2009, 06:21
    Last Post: - 2nd May 2006, 20:01
    Last Post: - 18th December 2005, 00:30
  5. PBP / XP Crash
    By pondindustrial in forum mel PIC BASIC Pro
    Last Post: - 27th November 2005, 04:16
