ok so if i anderstood:
my value a first is , lets say 2.267volts it s is my first value
if i take two mesurement separeted by 1 i know that, if the second one is differente than the first one,i moved isnt it?
so if i moved i probably want to know the angle (how many degrees i traveled)
lets say the second mesurement is 2.320volts that probably means i moved one way (actually left)
i know that the sensor sensibility is 0.66mv/deg/sec
my mesurement is spaced by 1s so i probably moved 2.320-2.267=0.053v so 53mv that would say i moved around 80,3 deg is that right?
if i m right then i could do mesurement spaced by 10 us it will be better for me
and how can i do something proper with only a 16f88 without proper math (integer) calcualtion?
