How to write/read strings EEPROM/LCD
Results 1 to 23 of 23
    Dec 2005
    Joe,
    Here's a post taliking about the "Flash Program Write". It's disabled when I select 16F648A I the EPIC Programmer, and the setting is completley taken away when I select this chip in Melabs Programmer 3.31, but maybe I don't really need it.
    http://www.picbasic.co.uk/forum/showthread.php?t=1076
    I've read some about using code space, but don't really understand. So is that part of the 4k space that is used when programing the chip? If so, then I would start storing strings at say space 3500 and then just have to make sure that the program doesn't get any bigger than 3499?
    I don't unserstand this:
    LCDOUT 254,1 ' Clears Display
    LCDOUT 254,128,"Here's how to output"
    LCDOUT 254,192,"Strings from code"
    LCDOUT 254,148,"space easily !"
    LCDOUT 254,212,"Where you put it"
    Isn't that just standard LCDOUT commands in decimal rather than hex? Sorry for all of the questions...this stuff is confusing since I don't know assembly language, and most of the examples use it.
    Quote Originally Posted by g-hoot View Post
    Joe,
    Yes that's all it is, but you are using codespace and not eprom. It executes fast and if you lack the knowledge to use eprom, well it works.
  1. Parsing Strings...
    By TerdRatchett in forum mel PIC BASIC Pro
    Last Post: - 15th February 2009, 05:13
  2. Please help with storing strings in codespace
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 16th May 2008, 02:02
  3. Processing lengthy strings
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 21st March 2006, 06:27
  4. I2CWRITE writing Strings to EEPROM
    By NavMicroSystems in forum mel PIC BASIC Pro
    Last Post: - 27th March 2005, 20:45
  5. reading 2c strings
    By beto in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2004, 16:26
