USBDemo, something to learn USB a little bit
Results 1 to 40 of 279
    Sep 2003
    INDIA
    Here's a small contribution from my end to support the good work.
    Thank you steve for the help
    regards.
    Quote Originally Posted by charudatt View Post
    regards.
    And I would think that a similar dev board for a '4550 would be practically the same except for the obvious pin differences...
    I hope so...'cause that's what I'm building...still waiting on the '4550's though...
    Sure,
    There's just a little something i would point so far. Yes the 1.5K is recommended if you don't enable the internal one as i did. Now i think the generic code do it for us... but for safety sake i did it in mine. the two 100nF could be replace with a 470nF. In some occasion it seems to be better when using a higher value. EasyPic 4 use 2X110nF but i changed it. It's just for safety sake so far. If it's working for you... use it
    Now, the Darrel's code mod comes really handy. It free 1 timer... really interesting...
    Instant Interrupts - Revisited, post 148
    http://www.picbasic.co.uk/forum/show...&postcount=148
    Thanks to everybody posting in here!
    Jan 2007
    Default 470nf cap substitute?
    Does anyone know if i can substitute a different value for the 470nf capacitor that pulls the usb+ to vcc? Somehow I haven't got any nf value capacitors - plenty of pf, uf...
    I read a post somewhere at some point where a guy said he was using a 2.2uf and it worked ok.
    Jan 2007
    Default usbdemo troubles!
    Hey!
    First, Mister E, thanks so much for putting this together, I can tell it will be a huge springboard for me, if i can ever get it to work!
    I already mentioned that I am using a 10pf capacitor instead of the 470nf one specified. I haven't got any nf capacitors at all! oi!
    Anyways, i loaded the included .hex(still cant compile it from source) and my computer recognizes an 'unknown usb device', not a HID device.
    Ive got a 4mhz resonator on there.. i tried it with a 20mhz and it didn't seem to do anything.
    Any advice please?! I took the day off work to do this stuff today, and it is frustrating!
    Thanks!
    Jan 2007
    Default thanks for the help
    i got it to work! Now to understand it all! Not to mention get it working alongside a USB bootloader.
    Thanks for the example. The code looks excellent. Way beyond anything I can conceive of.
    cheers.
    Oct 2003
    Australia
    Talking Works a treat!!
    Yep got mine working today too!!! Woo Hoo!!
    Golly gosh, loaded Mr E's sample prgram, connected the USB cable and Presto - Windows detected it and it started to work first time!!!
    On the demo PCB I added a serial connector so that I can program the 18F4550 via serial ICSP, and also added a couple a RS422/232 line driver receiver so that the PC can communicate via USB to serial devices.
    I'm sure I'll have more to add once I've played around with this toy some more.
    Cheers
    Squib.
    See photo attached.
    Last Post: - 14th June 2016, 07:55
  2. How to receive stream of bytes using PIC USART
    By unifoxz in forum mel PIC BASIC Pro
    Last Post: - 20th June 2009, 10:38
  3. Replies: 9
    Last Post: - 31st July 2008, 08:56
  4. PICBasic newbie problem
    Last Post: - 12th February 2008, 00:55
    Last Post: - 6th March 2005, 01:07
